Tonight I swept up a bunch of the flakes, about 3lbs out of 16lbs.
I'm looking to get a fairly smooth finish so tomorrow I'm going to scrape off the uneven flakes with a plastic scraper. I may follow that up with a sanding with a pole sander and 100 grit paper to smooth it out even more before the clear coats.
I'm still not sure what I'm going to do with the un-flaked apron. I'm either going to do another color coat and flake it again (in which case I have to buy more Devoe 224HS) or I'm going to try to apply it during the first clear coat. Any suggestions are welcome!
The floor looks good. I still think with a heavy broadcast there are too many black flakes that make it contrast too much - brings too much attention to the floor. I bought my flakes from originalcolorhips.com and the marble mix that I bought appears to have even amounts of black, gray, and white flakes. I noticed some of the other brands (quikrete for example) actually put in less black flakes compared to the other colors. I think this would have been better with the heavy broadcast. I still looks very good though, I will just have to change some of the other colors I'm planning to use to complement it better.
I was very happy with how the taped edges turned out. I used duct tape like many people suggested and it worked very good. You can see blue painters tape in my pics but that is actually only the second layer of tape. All edges where epoxy meets were done with duct tape. I removed the tape tonight from the garage door and back door openings. I will tape them again before the clear coat. Here's the edge at the garage door:
I'm actually not sure what to do with this exposed edge. Do you leave it like that or do you put some kind of transition piece there?
Here's a couple pics trying to show some of the flaws in the floor. The first one has light reflecting to show how rough my floor really is. The second one shows the spotty broadcast of flakes
...and here's a closeup of the flakes
