I am planning to apply my 1 and half kit of Epoxy Coat to my 550 sq ft. garage this weekend. The process starts tomorrow. Here is my general plan and thanks for any input that you might have.
Thanks...Kevin
Questions
E-C recommended that I not install a primer prior to epoxy. Others have stated primer coat helps to smooth things out and reduces potential for bubbles.
I am not using the flakes in the kit but plan to use the anti-skid. Should I add additional anti-skid? Should I substitute in an aluminum oxide anti-skid from local retailer and not mix two products in? Addition of flakes makes it hard for me to see small items dropped on the floor. I have no depth perception on flat surfaces.
Any recommendations on measuring instead of measuring sticks supplied in kit?
Should I mix all of part A together in another container, and mix all of part B into another container? I thought I would do this to get consistent mix of the two parts prior to mixing in the smaller batches when covering floor.
Installation Steps
Clear remaining contents from garage
Sweep garage floor
Blow out garage floor with gas leaf blower
Scrub entire floor with degreaser solution and wire brush
Rise floor three times to remove residue from degreaser
Let floor dry for at least six hours
Use Edco Dual Disc grinder with Dymaserts to scuff floor
Rinse entire floor after grinding three times
Let floor dry for 24 hours
Check for residue on floor rinse and dry again as necessary
Validate temp is below 90 and that humidity is five digits below current temp
Start process of applying first coat of epoxy in the evening and work till entire floor is covered
Work in batches allowing me to cover an area within 15ish minutes
Let floor dry for 18 hours prior to foot traffic
Let floor dry for 24-48 hours before heavy items
No vehicles on floor for three days at least
I am planning to paint rough edging below drywall and above floor with standard cement paint (possibly same color as wall later).
Thanks...Kevin
Questions
Installation Steps
Sweep garage floor
