My Free Bridgeport Mill
Provincial
Near Salem, OR
Copied from the Garage Sale Thread:
Things have been rather hectic for me lately, and I haven't had time to check out estate and garage sales. One item turned up that I had to jump on.
A friend keeps in touch with a machine shop his family used to own. He has a Bridgeport Type 1 mill, and expressed an interest in a part off a derelict Bridgeport they had back in a corner of their fab shop. They said he could have the part only if he hauled off the whole machine! He called me and asked if I would haul off he machine so he could get the part, which is a bearing housing on the end of the table.
When he told the shop that we would haul off the mill, they moved it out of the corner and told us to pick it up within three days! It was stored on a pallet. I was able to make time to swing by with my trailer and they put it on with a forklift, pushing it up the center over the axles with another pallet and a couple of 4x4's. This left the mill in a hard-to-reach spot. I was able to pry the pallet over to one side and could barely reach far enough with my forklift to pick it up using a chain through the lifting eye on the ram and a web strap under the head to level the lifting pressures. I cleared the fender by a half inch when backing out.
Once I got it into the shop, I started checking things out. I knew that one end of the lead screw had snapped off, and moving parts around allowed me to check check that the screw was not bent and the x-axis backlash was .040 without trying to adjust the nut. The y-axis backlash is less than .010, and both axes move smoothly and with little drag. The table turned out to be in pretty good shape, with only a couple of shallow hits from cutters. Probably better than most tables. The oil film on the quill had dried out and took a little coaxing to break free, as did the spindle bearings. Both move smoothly and easily now, and a light application of spindle oil has helped. No evidence of roughness in the spindle bearings!
The motor spins freely by hand, and the feed freed up and works full travel, with the kick-out functioning properly. At first, the driven pulley didn't want to rotate, but an application of Kroil and soaking overnight freed it up. Now both the v-pulley and the timing belt/back gear system rotate freely.
This left the cam for the high-low dog clutch as the only control still frozen up. I soaked it with Kroil and today removed the two cam follower screws that ride in the slots. I then carefully pried up on the cam ring and worked it off. There was some corrosion between the aluminum head casting and the cam ring, which I'll clean up and lubricate before reassembling it. The dog clutch assembly moves freely up and down in the head casting now.
I'm not far from being able to try it out under power. I'll set up a pigtail to plug into my 3-phase 240V power and first try the motor, then the direct and back gear drives.
If things work out, I may try to fix the lead screw by making a new end and heat shrinking it into a reamed hole in the end of the old lead screw. The damage is on the end where the bearing "floats", so it will not take thrust loads, only the torque of the handle being turned.
Here are some photos my friend took and sent me:
P
Provincial
Near Salem, OR
Today I made some more progress. I cleaned up the corrosion that was binding the Direct/Back Gear cam on the head. I scraped off the buildup of white powder and used a stainless wire brush to clean down to bare metal. I wire brushed the inside of the clutch cam and lubricated the moving parts. I had to lift up on the step pulley to get the pins installed back in the cam slots. The pins do not reach the end of the slot, and they are far short of the end of the slot when in the Back Gear position. There is a stack of shop-made brass shims between the clutch cam and the aluminum top casting. I assume they are meant to place the dog clutch in a position that accommodates clearance in both positions. Everything spins over by hand with no drag or noise, so I expect it to power up well.
Drive Clutch Direct:
Drive Clutch in Back Gear:
Another point of progress was getting the ram to move. I put a large bar clamp from the front of the column to the back of the ram. I used only hand pressure on the clamp screw, and about the time I maxed out my twisting force, the ram emitted a "pop" and moved forward! I shifted it forward about an inch, scraped the dovetails with a razor blade to remove rust and built-up crud, wiped it with a WD-40-soaked rag, and applied way oil. I then used the clamp to move it rearward nearly full travel, then repeated the cleaning and lubrication. After a cycle back forward, and cleaning/lubricating a larger area there, I was able to move it rearward full travel and clean/lubricate the rest of the dovetail. Now it moves back and forth full travel smoothly and with reasonable effort.
Clamp Applying Pressure to the Ram:
You can see my witness mark movement in the first photo if you enlarge it.
This evening I was able to clean and lubricate the ways on the knee y- and z-axis. They both work smoothly. I'll be cleaning and lubricating the the knee lift screw tomorrow.
It is actually a lot of fun to bring this machine back from the tomb. It will never be like new, but should work fine if not asked to hold precision tolerances on the x- and y-axes. The head and ram seem to be in good shape except for appearance. I believe that there is plenty of life left in this old girl!
RoninB4
Under My House
Rough looking BP but you sure can't beat the price. It will never be like new (as the OP correctly noted) but if not expected to hold location tighter than +/- .010 (pending testing) then it's still worth the re-work IMO. A free machine to mill, bore, and fly-cut? Heck yes. Parts and tooling still available? All day long and easier to find than some for the clones that are far more beefy. As far as the diminished accuracy goes, in some circles a BP is considered just a graduated drill press. A BP was never considered fast, accurate, or even stout. It's a good design that favors versatility and relative ease of changing from one operation to a different type of machining operation. Swing the turret around and you can machine something too large to fit on the table. Repair should be straightforward in this simple design and no electronic unobtainium like Deckel or Maho.
To the OP- Congratulations are in order (also the obligatory "You ****").
P
Provincial
Near Salem, OR
Thanks Aaron. Your project looks like fun, too!
I have too much going on right now to make very fast progress. Maybe if the snow starts to fly.
P
Provincial
Near Salem, OR
I got the Bridgeport running today. Not super-quiet in direct drive, but pretty good. Very quiet in back gear. Forward and reverse on the motor yields the same results. The quill power down-feed works well in all three speeds, plus it reverses. I can say the head has passed its operational test and I can move on to the lower part of the machine.
Packard V8
Spokane, WA
Bridgeports are like old Camaros; guys who know nothing about cars want one and will pay too much for them. When you get it cleaned up and the replacement handle done, it would sell for $2500 tomorrow.
jack vines
P
Provincial
Near Salem, OR
jack vines
Yes, but I'd have to take a brush, a quart of Rustoleum Dark Machinery Gray, and paint it!
