urbanG33K
He guys.
I have a liftmaster 3/4 HP garage door opener. It's lifting a bigger garage door mounted on tracks. The door I believe is 16 x 7. It's an insulated plastic door. It is on tracks and has a large coil spring running the length of the door.
The liftmaster opener appears fairly new as does the tracks, and the actual garage door. I don't believe they are original to the house and recently upgraded before the prior owners sold the house.
Basically I feel this is temperature related or something is out of adjustment. It happens when theres a quick temperature shift in the garage.
Eg: It's -18 Celcius tonight. My garage normally sits around 4 or 5 degrees celcius. When I open my garage door to warm up my car, I let my car run for about 5-10 minutes. The family piles into the car, I back out, click my remote and 1 of 2 things happens....
1) the garage door doesn't budge. The light flashes on the opener signalling obstruction.
or
2) the garage door comes down about 1 panels worth, stops and goes back up, then the light on the opener flashes and signals obstruction.
At this point, I have to get out of the car, pull the manual release and close the door myself. The door doesn't feel jammed as I can release it from the opener, then walk under the door and pull it down with 1 hand.
It never gets jammed openeing, only closing.
I have tried greasing the tracks. I have adjusted downforce to maximum and it still does it.Nothing is in the way of the optical obstruction sensor at floor level on the doors threshold and I have cleaned it.
If the garage is left open for an extended period of time, the problem rights itself.
It happens in hot weather as well. Same symptoms. Open the garage door, in rushes hot humid air, then the opener punts.
Where do I go from here?
or
