TheOtherGoose
At night my central A/C takes several (like 5) hours to drop my home's temp from 75 degrees to 74. The highest temp today, for example, was 84.
I can't figure out what's wrong. The four-year-old HVAC system is the correct size for the house, the system/filter is clean and the refrigerant is properly charged. I have checked the outside condenser and it's clean. The obvious things are good: the registers are open and the windows/doors are closed. I've actually tried a few different thermostats just to eliminate it as the problem. I've got cool air coming from all the registers, although I can't say exactly what the temp of the outlet air is.
It's odd - during the day, the A/C will maintain 75 degrees on a hot day, cycling normally (about 10-15 minutes every so often). Turn down the temp a degree or two (74 or 73) for a cooler night's sleep, though, and the HVAC struggles to reach the new temp.
Any ideas of what to have checked?
I'm quite frustrated with the situation... especially since I'm not asking much from the A/C. Could you imagine this system trying to achieve 70 degrees?
