My IR Hammerhead stopped working!
czgunner
WY
I'm bummed! It's one of my favorite tools.
Used it, set it down, tried to use it again and it just hisses.
Tried another air line, no go.
I oil it regularly.
I've owned it maybe 2 or 3 years.
I take care of it and never drop it.
What is most likely wrong?
I'd like to fix it myself if possible.
How do these come apart, and what parts should I need?
Direct from IR?
KinzeMech
Have you greased the hammercase? If it's 2 or 3 years old, it's past due for it unless it's a shelf queen.
helterskelter
Eh, only about a 1/2 turn each way.
I broke it good, huh?
If it's locked up it's probably broken pretty good. If there's no warranty take it apart and find the failed component then buy one from IR. Also post pictures here.
shockwave
Marietta,ga
I had this happen to a 1/4 air ratchet look at the spline and make sure no dirt for into it but it could also be the trigger button they have come loose from the air valve before on my 2115ti before
smothers33
sounds more like a broken seal. take it apart and see if all the seals are intact
C
czgunner
WY
Well, I took out the anvil and upper bearing and gear. That looked fine.
I couldn't figure out how to get anything else apart.
My tool guy is sending it in for a fix quote.
