My lab scope case.
2ndGearRubber
Pittsburgh
I recently made a thread which ended in me considering building a mobile case to house my Picoscope. I got all the parts in this week, and made it up this evening.
I purchased a bulkhead kit from Jarhead Diagnostics. I previously heard rumblings that Jarhead and Warwick based out of the UK were affiliated. I can at least confirm that the leads from between the scope and the bulkhead connector are Warwick parts. I was generally happy with the fit and finish of the bulkhead plate and the supplied BNC connectors from Jarhead. I purchased a pelican 1400 series case to use as the basis of the project. When I spoke with Jarhead via email they confirmed the dimensions of the 1400 series case were adequate, but implied they themselves had seen more applications using the Harbor Freight version of the cases. I think the brand is Apache from Harbor Freight.
The project involved drilling some holes, and fighting with the absolutely mind-bogglingly frustrating Pelican foam. It is only scored in the vertical Direction, so trying to cut a section out to be flat is extremely difficult. For the USB connection to the laptop I drilled a hole in the case to allow the Pico cable to exit. For removal of this cable, one would need to remove the grommet I placed in the case to prevent rub damage. However my scope pretty much always lives with the USB cable attached so I'll just curl it up and lay it on top when not in use.
Looks good.
A USB bulkhead fitting would let you remove that cord, but would probably need a bigger case to fit it in.
Dave455
Sussex, England
Nice job!
The way to get the pelican foam flat is to work out the size you need then remove that section completely. Cut it to thickness as best you can (on a bench) then re insert it upside down. The side you see looks o.k. that way!
2ndGearRubber
Pittsburgh
Nice job!
That ended up being my method. I had to use small chunks of foam to shim the irregularities underneath. Worked out pretty well, the scope has maybe 3/8 of an inch of total movement within the foam.
richfinn
Leeds, Yorkshire, England
Is there a protective cover that fits over the remote bnc connections on the outside of the case?
You now need some pico/jarhead/wts decals for the case
I wonder how hard it would be to install an appropriate tablet screen into a case like that to make it into a complete hand held picoscope??
2ndGearRubber
Pittsburgh
Warwick sells an option with a cap that can slide over the ports. Its more so designed for tool cart mount. You'd probably need a bit bigger case.
For a touch screen, I'd look for some sort of tablet case, with elastic straps on the back maybe? IIRC it needs to run windows for the pico software. Wireless USB connection mounted to the case perhaps?
richfinn
Any updates on this set up Scott?, I'm wanting to build one with a Panasonic tablet fixed into the lid and storage for current clamps/accessories etc. in a large waterproof case.
2ndGearRubber
Pittsburgh
That's very clever. Some thoughts from having mine in use a few years:
The extension female/female wires I used to connect the scope to the bulkhead connector should have been a bit longer. They haven't broken or anything, but they're under a bit of tension.
Locktite should be used on the male/male.bnc connectors for the bulkhead. They can come loose from connecting the bnc leads.
BukitCase
Oregon
I'm considering "updating" my ancient Tek 454 analog scope so googled Picoscope - so far, my only question is
What Fkn Rokit Surgun thought light blue text on a (slightly) darker blue screen was even VAGUELY readable? NOT off to a roaring success... Steve
richfinn
That's not actually the screen it's the hardware, it plugs into whatever windows device you are using via USB 2.0 and you can customize the screen to suit your needs 👍
richfinn
Thanks will bear that in mind 👍
