My Little 8' x 12'
Kinyocase
Missoula, MT
So while I am keeping my pole barn build on hold to get my house done, I decided that I would get my small shed back into shape. It started out as an 8 x 12 build to house whatever I needed it to house. The main downside of this build is the 5x5 pump house obliterating one whole corner of the shed.
Well anyway the only power in the shed was for the pressure switch and pump shut down. I had some electricity done in her to allow for two outlets and a main light as seen in the photos.
A couple months ago I picked up a SBC 350 with under 50k on it, and decided to store in right inside my door...it's a pain to walk over but stayed dry throughout the winter.
Today I got out and decided to do some cleaning. Within an hour I had move most things around, cut my bench top and placed it upon my bottom drawer units. Took my 500 ZL motor out from under a tarp and brought it into the work bench. Looking forward to finally using this shed to work on something.
Well I guess that's it for now. I will be doing little things on this shed as the summer goes on to make it more workable. I will be removing the giant plastic shelving unit with engine parts on it, and reclaiming that wall for other purposes. I will also remove all my exhaust parts from above the well pump house and continue to use that upper area for the storage of my R/C paraphernalia.
HSpencer
South Central US
Good project. An 8X12 is plenty to fit in a small shop. Good that you have the electric out there, and a light. I am anxious to see how you fit it up!! Thanks for posting your work and keep us updated!
Best Regards
Herb Spencer
