My look inside a failed Milton V coupler
kythri
Lebanon, OR
I'm still trying to determine why anyone finds Milton V's hard to connect/disconnect. Been running them for several months now, and zero issues connecting/disconnecting at pressure.
It's not like I'm gorilla-ing them or anything...
:lol: I tell the middle kid that all the time, "you gotta be smarter than what you're working on". Usually, in his case it's opening a cardboard box...:willy_nil
As I always tell these kids..... "You just have to believe in your self." "Believe in yourself" or just "BELIEVE!"
Or my other quote......... "Get pissed!"
L.Cheapo
Upgrading to Milton Hi-Flo couplings was one of the best things I ever did. Zero issues.
Please don't become the next SawStop guy, OP.
LXCam
Not a problem I have ever had.
Are you sure?
My moto from my performance products line is: From wild to extra wild we got you covered with **** ya never knew you needed
Applicable?......I think so. :lol_hitti
md21722
Mt Juliet, TN
I've been using them for a year and a half and haven't had any problems.
I saw that Flexilla sells high flow couplings now. I suspect that's what the Master Force is.
Good to know that V style plugs fit in these couplers.
Fish_Stick
I switched over for an impact to the Milton V and I'm not sure about the difficulties either. I personally feel the Milton A is more difficult to connect since you have to pull the collar back first and then push in the plug in and then sometimes pull the collar back up. Far from a body builder too so... :dunno:
dnschmidt
Phoenix, AZ
I'm old and feeble and I've got no problems with the Milton V other than they don't last very long prior to leaking. Been using them with my SATA guns forever. Switch to the Dixon or the Prevost version and problem solved.
L
Leveleer
Superior/Duluth
As the pressure rises in the Milton V, the highly compressed sliding o-ring becomes so tight that it becomes almost wedged to the point of seizure. This is a terrible design.
At lower pressures it is much less noticeable.
Rustypigeon
USA
I have no problems with my Milton V's. If someone lacks the hand strength to connect a Milton V with ease, they lack the hand strength to work on mechanical things.
kythri
Lebanon, OR
What's high, and what's low? Numbers would help.
md21722
Mt Juliet, TN
I thought the video was interesting because I've never taken an air coupler apart. Wouldn't mind seeing disassembly of the Mastercraft which I think is a Flexzilla as a comparison.
Fcvapor05
Am I the only person in the world who pulls the collar back to make connections?
kythri
Lebanon, OR
Yeah, on the Milton V-Style, you don't have to pull the collar back.
Another one of it's awesome features.
L
Leveleer
Superior/Duluth
I have tested the force required to connect several different types of hose couplings.
The pressure I use is 120 PSI.
Here is a test of the Masterforce High flow and here is a test of the Milton V.
The Masterforce is a much better design as the area under pressure is significantly less and there is no need for a highly loaded sliding o-ring with its resulting friction.
EOC_Jason
Bentonville, AR
I don't see how people have trouble with couplers under pressure... Everyone has their technique but for me it's easiest to slide the release back some while inserting the male end then I pull the release back in to lock it in place. Trying to insert a coupler just by sheer force an expecting it to lock in place is a waste of energy... It ain't rocket science.
L
Leveleer
Superior/Duluth
I have been attempting to make it clear that having a sliding o-ring seal that is loaded varying amounts according to the pressure applied is a really really bad idea and having a poppet that can shift off center causing the o-ring to catch the edge of the housing thus jamming in the open position is a really really bad design.
kwschumm
Olympia, WA
Unless the application involves a constant source of lubrication it seems the O-rings will have a short life in situations where couplings are made on a regular basis. If you plug a hose in and leave it connected it's not a big issue.
Jeepster04
Ive had a milton V blow the oring out. Nothing out of the ordinary, just uncoupled it one day and got blasted with air. At the time I just pushed the air chuck back on to stop it.
Once I got it part I found that the oring blew out then got lodged in the spring loaded valve. If I wouldnt have ruined the housing by tightening my vice too tight (thing is soft) I couldve saved it.
They are rather hard to push on but its not an issue.
Rustypigeon
USA
I believe the reason for the Milton V design is that is allows you to use high flow V fittings in addition to A and M style fittings.
Do the better designed high flow couplers allow multiple different fittings to be used?
md21722
Mt Juliet, TN
Milton says an I/M will fit, and it does, but its sloppy and seems to leak some air.
L
Leveleer
Superior/Duluth
Here is one that does:
It's a Masterforce brand high flow:
It's a much better design than the Milton V.
I've never had the seal not line up. Never. I have pushed the seal back with a nail to use the fitting as a blower and had a misalign a handful of times but it's just never been an issue inserting the ends together and that's after 35 years of being a carpenter, using nail guns, drywall texture guns, etc etc.
B_Bimmer
Eastern Iowa
I have been completely satisfied with milton v couplers, that said, what would you consider the best coupler Leveleer? Will it work with v style plugs? I am always willing to try something new, although I am now quite committed to v just because of the number of tools and locations I have and use regularly.
L
Leveleer
Superior/Duluth
I like the Masterforce HiFLow from Menards. It's much easier to connect and disconnect then the Milton and takes both industrial interchange 1/4 and V style.
Masterforce hiflo
