aerobb
I was reluctant to post after seeing all these beautiful builds, but what the heck It's probably good for some to see that everything doesn't have to cost an arm and a leg.
This is my build:
30x40 Barn with a real loft. 10' ceilings (yes I know it's short). Loft is full size with 6'6 at the hip up to 10' at the peak, stringer at around 7'10 every 48".
I live in Amish country in NW Pa. My Neighbor has the sawmill and his son (and crew) did the work. 4 Days from start to finish of the shell.
I'm currently in the backfill and compact stage on the interior. It's almost winter here in the snowbelt so work will probably come to a standstill. but scheduled for the spring will be:
1. Concrete with radiant heat. just finished the design spec's and I'll probably get a quote for an early spring pour
2. Elec. I have two services to the house now with one mostly unused, will be running a sub in the barn
3. Insulation and Overhead doors.
Here's what I've got into it at this point.
$250 for the dozer work. (but that was more work than just the leveling for the barn
5000 for materials of which 2500 was metal roofing
2500 for labor
I'm estimating ~4k for concrete, and about 3k for the other things I've listed above. Overall I should be in for around $16k
This is my build:
2500 for labor
