My MIG cart
MarkG
Elgin, IL
I posted this back when I finished it a few years ago, but know there might be some new guys on here by now! If not and if the mods want, by all means, I can delete it or they can!
I got my MIG cert at a local community college and shortly thereafter, bought a Hobart Handler 140. (I've since sold it, but it was a great machine)
The pics tell the story here. If I ever buy another welder (maybe the 210 MVP or an Alpha TIG) I'd use the same cart. I can't stress enough how useful a good 'holster' is on a cart! I just used a section of mild steel tube welded to the frame. Also, the height makes it easy to see controls, adjust, etc. I only used a small bottle underneath, since I was just a 'hobby welder'.
The 'wide-track' design of the front casters made it very stable.
The bottle is secured by a steel ring of flat stock welded to the base and a brace and 'openable ring' at the top. It's hinged at the top to allow me to tip the bottle to the side for removal/replacement and I used a clasp to keep it closed.
The flat metal gussets were cut from the base of the hand truck. The shelves are mild steel diamond plate. Of course, the whole thing had to match the welder, so the wheels were sprayed with Krylon 'Fusion' plastic paint.
Chevy-SS
Rhode Island
That's sweet. Nicely done.
I have AlphaTIG200 and I built custom cart, but made it out of wood, so that I can easily modify as needed down the road. Plus I wanted to make sure the whole thing would fit under my workbench.
MarkG
Elgin, IL
Thanks. I've been reading about that machine! I think if I bought another, I'd get it, since I'd like to work on my TIG skills.
raffaelli
Great idea! Nice job!
Chevy-SS
Rhode Island
Very happy with this machine. It was recommended by a bunch of members on the forum here. I've been using it for a couple of months, just practicing so far. TIG requires surgical precision, very challenging, but interesting and enjoyable.
I'll be doing mostly stainless steel work. The AlphaTIG200 comes with a pretty good kit. But I have added a few things, like dual flow meter for purging, and #9 torch, FUPA cup, etc...
Good luck with whatever you end up buying!
MarkG
Elgin, IL
I'll probably put it off till I either get busier or get a 'real' job. Kind of hard to justify buying a welder (again!) when I don't need one and so far, haven't even sold any of the projects I've made hoping to offset or somewhat justify owning one! :S
