Between 705 & 1200 SQ/FT My Mini Garagemahal
F
fouckhest
Greer, SC
Kept at it last night, while it may not look like a lot of progress, it was a big prep step for some good work this weekend.
Finished cutting the inner rockers out, got them smoothed out and did a little more work on the pinch welds. Should be in a good spot to head to the metal store at lunch, grab some 90° angle and be setup for a solid weekend of work.
Driver side rocker - on my way to the metal store I'll be stopping at HF to grab a slide hammer to fix that spot that is "smooshed" up. I still need to trim the top of both sides of these inner rocker areas, but I wanted to wait until I had all the components so they can be mocked up to save from trimming too far.
55044158321_59eb9cb92c_c.jpgUntitled by fouckhest, on Flickr
Passenger side
55044158331_14d706960b_c.jpgUntitled by fouckhest, on Flickr
Pinch welds looks pretty good at this point
55044158286_85381901ee_c.jpgUntitled by fouckhest, on Flickr
55044498935_c03d781643_c.jpgUntitled by fouckhest, on Flickr
Couple shots from under the car, well, b/c I think they look cool!
55043264642_d573a66507_c.jpgUntitled by fouckhest, on Flickr
55043264647_667924b8d5_c.jpgUntitled by fouckhest, on Flickr
Hope everyone has a good weekend, stay warm out there!
F
fouckhest
Greer, SC
I hope everyone had a good weekend, lots of work in the shop, doesn't seem like much at the end, however, I've had to tell myself I've dug about as deep as I am going to go and now is when everything has to be completed in a way that it is sealed up forever.
Saturday morning dug out the new slide hammer to start fixing the mangled rocker pinch welds. My understanding of one of the attachments was not correct, so off to the hardware store to get some hardware for a quick modification.
I thought "clamping" to the rocker would work, so welded these nuts on, sharpened the tip of the bolt, but it didnt not work as planned, so out came the BFH and a 2x4, guess I should've tried that first, but oh well, lessons learned
55048745187_e260a1fc27_c.jpgUntitled by fouckhest, on Flickr
Started mocking up the 1/8" x 4" flat bar that will be used to tie in the door frame to the pinch welds
55048745167_d29d671739_c.jpgUntitled by fouckhest, on Flickr
The majority of Saturday was spent with the wire wheel in hand, making a huge mess, but prepping all areas for welding. Then date night with the wife to round out the day.
Back at it Sunday morning after some errands, I finalized the size for the rocker plates, drilled a bunch of holes, fired up the paint shaker, got the back of the plate and inside the rockers sprayed with weld-thru primer
55049835513_8702e09786_c.jpgUntitled by fouckhest, on Flickr
55049992140_59389949a5_c.jpgUntitled by fouckhest, on Flickr
While the paint was drying I knocked out a plate to cap off the end by the base of the cage hoop
55049649816_85c2ba8589_c.jpgUntitled by fouckhest, on Flickr
55049906344_39b99c8aee_c.jpgUntitled by fouckhest, on Flickr
55049906274_be75378a76_c.jpgUntitled by fouckhest, on Flickr
Got it tacked in and moved onto the flat bar
55049906664_ac1abf4d18_c.jpgUntitled by fouckhest, on Flickr
Got the flat bar installed, fitted and tacked in, the bottom rosette welds burned in nicely, the tops aren't as nice, I will go back and add some stitch welds at the bottom edge of that upper area, same with the the bottom edge where the flat bar meets the pinch welds. I ran out of energy/motivation yesterday and decided to call it quits around dinner time
55049993595_893783a656_c.jpgUntitled by fouckhest, on Flickr
55049836508_a5aec7b8ca_c.jpgUntitled by fouckhest, on Flickr
Not a great photo, but its nice to look at this and not see the mangled pinch welds, that is something that irks me to no end now, so happy to have it fixed
55049907299_ddf7201e31_c.jpgUntitled by fouckhest, on Flickr
Need to get the other side knocked out next, will likely start on that and then decide what next steps look like, with this much done I am torn between starting on the headers or starting to final weld all of this in so its done and no longer a looming task for another day.
Hope everyone has a good week!
F
fouckhest
Greer, SC
Productive night in the shop last night, but when it is rinse and repeat from the opposite side, things tend to go a little easier.
Buttoned up the rockers and got them tacked in
55051682198_3edfdfa155_c.jpgUntitled by fouckhest, on Flickr
55051760319_6752141211_c.jpgUntitled by fouckhest, on Flickr
Will likely be a short work night tonight as I have to pack and get ready to leave for a work trip tomorrow morning. I am telling myself that the silver lining is that I'll be able to take a forced break for a couple days and come back to the shop with fresh eyes and a brain full of thoughts on what my next steps look like.
F
fouckhest
Greer, SC
I hope all is well with everyone, and all impacted survived snowmageden 2026! :ROFLMAO:
Been a busy week for me between work travel, trying to prep for the pending winter weather that still has our town moving slower than normal.
Silver lining, we didn't lose power, which meant I returned home from a work trip to FL and was able to spend some time in the shop this weekend.
I returned home to a package from Benchmark Abrasives, I know this has been mentioned a couple times in other threads, but I checked them out after a couple recommendations from @zmotorsports and @quadrcr87 and cannot speak highly enough about the quality! After going through the sample pack of flap discs (which @SilverJimmy recently mentioned), I've been back for cut off wheels, more flap discs and wire wheels for my current project. Most recently decided to check out a sanding disc for my 10" sander combo, which gave me a good excuse to replace the belt as well!
55063936183_ae01c1960d_c.jpgUntitled by fouckhest, on Flickr
With a little shop maintenance and cleanup completed, it was time to get to work. Replaced my front brace that ties in my new inner rails to the rockers
55063748826_2b7487da5e_c.jpgUntitled by fouckhest, on Flickr
Then decided to start making some gussets, evo saw for some nice clean 45° cuts
55063927433_fb71e31ee1_c.jpgUntitled by fouckhest, on Flickr
Used 1x2 tube in the rear since I could get one on each side
55064103030_e8d347d6d9_c.jpg by fouckhest, on Flickr
Front got braces on the rear side only due to access, but used 2x2 for these
Next up was to move the front side of those front cross braces, in order to get to those I had to cut away an outer edge of the inner fender.
55063928073_b244f950e4_c.jpgUntitled by fouckhest, on Flickr
Added a gusset on the outside to tie into the rocker along with the panel to cap the area exposed inside
55063932803_f3fda7606a_c.jpg by fouckhest, on Flickr
Wanted to add an additional panel that will cap the area between the gusset and the other cap, so made a little template, drew up some lines and broke out the bead roller...took attempts to make one I could live with
55063754391_93ac3bd995_c.jpg by fouckhest, on Flickr
Will save everyone the iterative process, but this is where I decided to call it done. Not perfect, but knowing this is the back side of the front wheel well, no one will really see it, so it makes for good practice!
55062858122_c22f860006_c.jpg by fouckhest, on Flickr
55062855512_79daa1b3ca_c.jpg by fouckhest, on Flickr
F
fouckhest
Greer, SC
Hope everyone has had a good week and all my southeastern friends are getting geared up for some more winter weather this weekend.
Been a busy week, garage time has been hit/miss, which is always a bummer, however, got a couple packages from the brown truck yesterday
First off is a new tool I've been eyeing for a while, been watching the HD deals thread and haven't found the right "deal" but on the HD site there was a decent enough deal on this little M12 grinder that I've heard good things about, so decided to pull the trigger Wednesday afternoon and it showed up yesterday. It came with two of the bigger batteries and one smaller one, so that brings me up to 5x batteries for the Milwaukee tools, which makes it nice should I want something else, I can buy the tool only
55068229193_56976cbff4_c.jpgUntitled by fouckhest, on Flickr
I like how with the bigger batteries the tool will stand up, rather than having to lay down....oh and you can see my fish plate design for the rear chassis rail, that is going to be a project for this weekend
55068905244_84a63612b8_c.jpgUntitled by fouckhest, on Flickr
Package number 2...
I am pretty excited about this, I am getting close to needed to put the engine back in the project car to start framing in the tunnel, one big component of that is going to be routing the exhaust and ensuring I have adequate clearance. One component of the exhaust I've been researching and really want to incorporate into this build is megaphones, so ordered these up from JMD Tubes and they showed up yesterday. If anyone is looking for a great vendor, I cannot speak highly enough about JMD, Made-in-USA products, super high quality products, packaging and always ship very quickly!
Will need to get these tacked up, but they certainly look cool!
55068229178_5a9edd61e6_c.jpgUntitled by fouckhest, on Flickr
Have a good weekend, stay safe if you are in the snow storm path and stay off the roads if you dont know how to drive in snow! :cool:
jcarapet
Texas
I bought the gen1 version of that right angle die grinder a week before the gen2 came out :mad:. I love it for weld prep, but it does have power limitations. The gen2 solves a bunch of them supposedly.
F
fouckhest
Greer, SC
Funny b/c when I was shopping I kept seeing photos of the one with the metal trigger and thought it looked more robust, then got this and it seems that it is an upgrade. I am excited, this wont be used for hard work, mostly metal finishing in tight spots
Jealous of your heated shop in this frigid SC winter. 🥶 I have found the same thing with the larger M12 batteries, especially on my drill. I got so used to standing up my M18 tools on the battery it became habit.
It is nice, but I really need to do something above the roll up door, it lets a lot out, might be a project for today!
Megaphones?!?!?!
*imafan
What other components will you have in the exhaust?
Kinda long tube / kinda equal length (+/- 10%) headers into 4:1 merge, hopefully into the megaphones then into Z-pipe, straight back to behind the axle, then will make a straight pipe section and a muffler section to swap in/out
Webster's Dictionary, "Megaphone": 1) let everyone know you have a motherf'n V8 stuffed in your engine bay, 2) make sure the dead are aware of your arrival, 3) the V8 has been eating a lot of beans... :ROFLMAO:
Exactly! Honestly the Audi 4.2 sounds super good with just a catback, I had a b6 S4 avant with a nice catback and that car sounded amazing, I am hopeful that there is a combination in all the components that will make for a unique sound
cccoltsicehockey
Charlotte, NC
Love a Megaphone exhaust. Done right Megaphone exhausts can make some v6 almost sound like a v8. Excited to see what you come up with @fouckhest.
F
fouckhest
Greer, SC
Hope everyone had a good weekend and all my southeastern brethren are staying warm, looks like we are finally heading out of the deep freeze!
As they saying goes, something about best laid plans....Full of ambition on Saturday morning, I knocked out my end of week work BS, headed to the garage, finished up the fish plates for the rear chassis section
Belt sander is such a great tool! This is a stack of 4pcs
55076038636_da8c481458_c.jpgUntitled by fouckhest, on Flickr
Cleaned up the chassis rails for some weld thru primer
55076238908_5987e194fe_c.jpgUntitled by fouckhest, on Flickr
One side tacked up and cleaned up
55076238938_752ca37382_c.jpgUntitled by fouckhest, on Flickr
Went to weld the other side on....womp womp, out of welding wire, by this time the snow was dumping enough that I decided I still had plenty to do and pivoted to cleaning up the rockers on the outer edge to prepare for welding the pinch weld to the new plate, this made for a long day of sitting in the chair with the wire wheel over head, but nice and clean
55076291734_8510a4c34c_c.jpgUntitled by fouckhest, on Flickr
Once that side was done, my arms where pretty tired, decided to call it a productive day and settle in to relax....this was the final snow accumulation, I'd say that we had a solid 4-6", nothing crazy, but certainly a nice coating!
55076317904_1baff93c89_c.jpgUntitled by fouckhest, on Flickr
55076062461_379da0e2c9_c.jpgUntitled by fouckhest, on Flickr
Sunday morning, started a little slower, enjoyed some coffee on the couch, then back at it to finish up the driver side
55076036356_5e83426586_c.jpgUntitled by fouckhest, on Flickr
Kept plugging away at a few other little things, by 230p it was looking pretty sunny out, so the wife and I decided to see how the trusty Colorado would fare making it out of our shady little neighborhood, made it down to HF for some welding wire and replenish the garage beers for a couple afternoon relaxation beverages
55076036471_b5df41b7c8_c.jpg by fouckhest, on Flickr
I managed to get the passengers rocker welded out and most of the way smoothed out, then last night headed to the garage to finished grinding down all the welds to hopefully make for a nice smooth pinch weld/rocker
I think once this came out pretty decent, especially for something that will rarely be seen, but I will know its there and was done right
55076238853_9a94e5b32f_c.jpg by fouckhest, on Flickr
I spent the rest of the evening working on the driver side, made it through a couple rounds of tacks and grinding, should be able to get that finished up tonight
zmotorsports
Northern Utah
Nice job Mike. Fish plates or doubler plates are a good idea on butted joints such as those. I have also been known to drill holes in the tubes and install them on the inside, then plug/Rosette weld them and then metal finish them as well. Depends on the vehicle, but they serve the same purpose, just depends on how I plan on finishing the chassis.
F
fouckhest
Greer, SC
Thanks, Mike! Always appreciate your comments/feedback and they make me feel much better when you say they are a good idea!
I hadn't thought about them on the inside, but that is a good idea as well, especially if it was a high end hot rod like you used to build, I am sure that would add to a nice clean chassis!
I put a little more effort into these to make them looking kinda cool in the case that someone is ever under the car, but most of this will never be seen unfortunately
F
fouckhest
Greer, SC
Hope everyone had a good weekend!
Been steady working away on my project car, good/bad, there hasn't been much photo worthy, just lots of welding. As mentioned, kept busy each night last week after work a couple hours at a time, trying to bounce around in methodical ways to not introduce any warping, pulling, misalignment, etc. I've been using the opening/closing of the doors as a good check off, so far so good!
That being, couple quick updates on getting the main inner chassis structure glued together
55085611717_ef0399df97_c.jpg by fouckhest, on Flickr
Almost IG worthy weld photo o_O but it is amazing how much better welds look with good base metal
55086869315_b6fea7c536_c.jpg by fouckhest, on Flickr
Front sections were welded up and ground smooth in prep for the a yet to be designed fish plate...might work on that tonight actually
55086501976_fdd64cdf9e_c.jpg by fouckhest, on Flickr
This weekend I spent some time focusing on getting the bracing onto the rocker sections, had been debating how I wanted to tackle this, and well, I followed the GJ / @zmotorsports "Overkill" approach which resulted in a section of 1x1 angle that will reinforce the pinch weld and provide a locating point for the 1x2 rectangle tube
This was during mock-up while working on the fit up
55086871575_e7d5c32a01_c.jpg by fouckhest, on Flickr
With my mind made up, it was time to drill a bunch of holes for fillet/rosette welds in the 1x1 angle...tacked both side together and marked up
55086871670_e5160deae3_c.jpg by fouckhest, on Flickr
55086503666_815072894f_c.jpg by fouckhest, on Flickr
Trusty drill press putting in some work
55086768029_6576cc1c3c_c.jpg by fouckhest, on Flickr
Finished up, don't remember how many holes, 50+ I think, these are to allow for the angle to be welded to the plate on the rocker as well as the bottom of the 1x2 rectangle tube
55086768019_ffbf1b4fbc_c.jpg by fouckhest, on Flickr
After some final fit adjustments, got a few fillet welds on the angle in as well as tacked the rectangle tube in place.
55085615342_12df4911a3_c.jpg by fouckhest, on Flickr
55086769764_1b3912fca3_c.jpg by fouckhest, on Flickr
This got me to a point where I had just enough time to do a quick shop cleanup before we had to get ready to go to some friends house for the sports competition. Hope everyone has a good week!
F
fouckhest
Greer, SC
Been a busy and productive couple evenings, lots of welding, continuing to learn a lot, welds are far from perfect, but I am confident in their strength.
Monday night I spend a bunch of time laying out where I wanted to do the stitch welds, then got the start/stops tacked up. In hindsight, I wish I would have gone back and knocked the tacks down a bit, but well, too late lol'
Thought this was a cool photo
55087685881_ec7046690e_c.jpgUntitled by fouckhest, on Flickr
That took up all of my free time Monday evening, then after work/before a call last night I got out and start gluing it all together. Don't look too close or zoom in too far...the top welds will get covered by a yet to be built trim panel....The lowers I will likely take a flap wheel too at some point just to smooth them out, but thats a future me chore
55090037571_8a7ce947a9_c.jpg by fouckhest, on Flickr
55090240548_47cb28ced9_c.jpg by fouckhest, on Flickr
....it always takes walking away, coming back and looking at where these welds are, realizing how infrequently they will be seen to realize I just need to keep plugging away and not let perfection get in the way to good enough!
F
fouckhest
Greer, SC
Not much photo worthy car project wise today, more welding and unfortunately grinding...but progress is progress.
In other news, FBMP strikes again, Tuesday evening while on a call I was mildly distracted but something caught my eye that I've been passively searching for on/on for a while....yesterday at lunch I went and picked up this old arbor press
Its not a Dake, but seems to be a solid older unit, Greenerd seems to make a nice product, the price was right and it is certainly solid. Now I need to give it a little love and clean it up, then a place to mount it....new to me tool day is always fun.
55091753936_7651b8ca39_c.jpgUntitled by fouckhest, on Flickr
Hopefully get some more garage time in tonight and this weekend....maybe one of these days I'll have an exciting update! :cool:
F
fouckhest
Greer, SC
I too have beencon the hunt for an arbor press. Not really sure whyI want one when I have a perfectly good 20 ton press, but its been on the list of goodies I want for awhile now. Look forward to seeing how that one cleans up.
I am in the exact same situation, been on the lookout for a year or more, while the 20T HF (even with air over hydraulic upgrade) is nice, this just seems like it has a use case.....I'll let you know when I find the first one! LOL
F
fouckhest
Greer, SC
Slickest mount I ever saw for an arbor press was in a customer’s shop. They mounted it to one of the legs of their two post lift. I bet you could build a mount that uses a receiver hitch so you could remove it if needed.
That is an interesting concept, Sterling, I like the thought process there! That might be tricky in my garage, but certainly has me thinking about how I could anchor it to the old exterior brick/block wall that is exposed in the garage. I might need to have a thinkin beer or two on this tonight 🤔 🍻
F
fouckhest
Greer, SC
Hope everyone had a good weekend, it was rather busy in our world.
Quick recap of a couple things I've been working on....my silver GTi was ready to be picked up from my mechanic buddy after going through a few things and catching up on some maintenance items such as replacing a torn and couple soon to be bad CV boots along with fixing a nagging oil leak that I was sick of cleaning up.
That being said, with the Cayman being a PITA to get in/out of the driveway at my step daughters house, I knew the GTi would equally as bad or worse. I bought these driveway ramps a couple months ago, but weather has not been nice enough to get them installed, but last week it was very nice so ran over and got them installed.
Drilled a few holes for some red-heads
55092581088_23a2d8460a_c.jpgUntitled by fouckhest, on Flickr
Bolted down and ready for use
55091494242_ce9063635d_c.jpgUntitled by fouckhest, on Flickr
Fast forward to Saturday morning, picked up the GTi, played a little car jenga and now both cars are tucked away together. I need to get back over there with some spray detailer to give them both a wipe down and put their covers back on them
55098365785_ec861d0bcc_c.jpgUntitled by fouckhest, on Flickr
With that complete, we had a small window of free time before meeting some friends for a late lunch/happy hour to catch up, so I made my way to the shop for a much needed clean up of both the shop and the basement, then I got to put together another new tool. While not in my normal over the top or go big tool purchase, this was a stop gap to see how far I can get without needing to go spend big money and then dedicate the valuable floor space for a proper box and pan brake.
Knowing there are lots of good/easy upgrades, it was a cheap barrier to entry
55097126232_c56b6d0cf4_c.jpgUntitled by fouckhest, on Flickr
This seemed like a good mounting spot that will hopefully help me keep my work bench clean
55098001306_a3cba5e055_c.jpgUntitled by fouckhest, on Flickr
Fast forward to Sunday, after some morning errands with the wife it was shop time. The intent of the brake was to be able to put this little flange on some sheet metal to make a closeout panel for where I reinforced the rocker area. This was a fun project, got to use the new brake, finally broke out my dimple dies and put the new arbor press to work!
This was testing out the 1", 3/4" and 1/2" dies to see what size I liked for this panel
55098002536_bd3cbcbc67_c.jpgUntitled by fouckhest, on Flickr
This is the test piece after I decided on using the 3/4" and 1/2", all in all, I am happy with how this turned out
55097127467_7c0c684ed2_c.jpgUntitled by fouckhest, on Flickr
F
fouckhest
Greer, SC
That looks very nice but are you sure you want such a nice place for road grime and moisture to collect and then begin to corrode all your nice fresh work? Remember, RUST NEVER SLEEPS!
Thanks Sterling, that part is actually on the inside of the car, that is the bottom of the door sill. Everything will get primed behind before those panels get welded in place.
F
fouckhest
Greer, SC
Not sure where this week has gone....been getting up shortly after my wife leaves for the gym and heading to the shop for some early morning work to get make up some future lost shop time while we are in CO skiing next week....but its been a nice change to my routine, going to do my best to keep it up when we get back.
Project of the week has been to get the inner rocker close out panels finished up
Started by making 4x more of the same shape/size panels as my test piece (looking forward to upgrading that little bender when I get back, it works fairly well)
55102838213_9e9a7d2abd_c.jpgUntitled by fouckhest, on Flickr
Lots of fitting to get them to where I was happy
55102633196_11e55795a5_c.jpgUntitled by fouckhest, on Flickr
Tacked the two pieces together
55105876415_58dbc0ed0e_c.jpgUntitled by fouckhest, on Flickr
Guess I missed taking photos of welding them together, but that wasn't that interesting, you can see here, lots of layout time, then very carefully center punched, then pilot drilled I think 68 future holes
55105498891_b7d6395996_c.jpgUntitled by fouckhest, on Flickr
55105876410_b9f57cee8e_c.jpg by fouckhest, on Flickr
Then onto two different size step bits to 1/2" and 3/4" before using the new arbor press and dimple dies
55105871760_f62e59b13f_c.jpgUntitled by fouckhest, on Flickr
Then did a quick mock up last night after winding down for the evening
55104614582_5d3937b7e0_c.jpg by fouckhest, on Flickr
55105758814_a43de48feb_c.jpg by fouckhest, on Flickr
Pretty stoked on how these came out and they certainly helped me come to grips with where to say "okay thats good enough,"....I think!
SilverJimmy
Prescott/Flagstaff, AZ
You need a rivet spacer fan if your going to be doing much more of these type projects.
They work great for laying out evenly spaced holes, and it does it in seconds!
F
fouckhest
Greer, SC
That would have made this job MUCH easier!
I've wanted to buy one of those for a while, didn't think far enough ahead, but thanks for the reminder and helping me spend some more money, just ordered one! LOL
That being said, I likely wont got super crazy with them, this seemed like a cool location to give them a test.
F
fouckhest
Greer, SC
Mike, what are we, chopped liver? I love seeing the work that goes into the projects, especially the hidden stuff.
Haha, never Bob!
It is funny how perspective of where you are working and what is in line of sight changes how much you focus on any particular thing. I've found myself spending SO much time on certian things, only to lower the car back down and realize I've been looking at it from an angle that eventually will basically be invisible. :geek:
F
fouckhest
Greer, SC
In other news, got home late Friday night from our annual ski trip out west, snow wasn't that great but 3 out of 4 days were certainly enjoyable and, well it wasn't work!
After picking up a couple of the pups from "camp" Saturday morning and a little housekeeping, I figured I'd go out to the shop and see what I could get into.
Staring me in the face was the HF bender that I knew I wanted to upgrade, so figured that was a good project to get started on. After much fiddling around and mocking up, here is what I landed on.
Couple fixture clamps to hold the upper die down, along with a piece of 1x1 tubing to reinforce the up die, it seemed like a reasonable approach
55127262853_f4718c9848_c.jpgUntitled by fouckhest, on Flickr
55127471980_2b22f7cfc4_c.jpgUntitled by fouckhest, on Flickr
Fast forward a few hours and it was fully welded out, got some chassis & roll bar paint applied to all the raw steel, I called it done until it gets used and see if future modifications are needed.
55127262848_630bf7eca9_c.jpgUntitled by fouckhest, on Flickr
Not much for updates on the project car, been working on how to modify the rear subframe so that I can get the dual 2.5" exhaust pipes through. I pulled the axles, control arms, spindles, etc off and left them on moving dollies so I could get the subframe and rear end back mounted in the car
Yard art car (as my wife call it) patiently waiting its turn in the shop
55127324259_0e5274a0ee_c.jpgUntitled by fouckhest, on Flickr
Trying to decide how to get a bushing mounted up top to do away with that big aluminum mount on the right
55127473090_4bd7482296_c.jpgUntitled by fouckhest, on Flickr
Between Sunday afternoon and yesterday I made up a couple iterations of mounting plates, both of which have been unsuccessful....spent WAY too much time drilling that big hole in the steel plate....
55126199067_9da12145e4_c.jpgUntitled by fouckhest, on Flickr
This morning I got back out to the shop before work and got the subframe and diff removed and up on my make shift table....this will be my project for tonight to see how what I can come up with
55127364649_7faf432211_c.jpgUntitled by fouckhest, on Flickr
