Cdubu52
Beer Brain > Analysis Paralysis
It's amazing how a beer/beers and a "**** it" can send the project moving forward! I had to do that in a similar situation with the '78 El Camino SS I had. Decided to give it the Trans Am treatment with snowflake wheels and a hood shaker...cutting the hole in the hood took A LOT of beer/confidence, it all worked out great![]()
Liquid courage is a useful tool when it’s the proper amount. If you wake up in the morning and not remember doing the work, then it was too much but sometime it’s genius work that happened!
i've got a the wheel dollies that I set the car on when it has the suspension under it, so hoping i can use those and some 4x4 scraps I have laying around to make something crude. It doesn't need to go far, just manageable to moveThat is a big accomplishment. Are you going to build some sort of heavy duty dolly to roll it around on?
My entire jeep tub project moces great on 3 harbor freight flat furniture dollies. 2 are connected with a 2x4 and one sits in the front with a chunk of 2x6 on it. Doesnt take much to roll on good concrete. It even does well rolling it outside and crossing the transition coming back into the shop
Untitled by fouckhest, on Flickr
Untitled by fouckhest, on FlickrI've been going to the Veil since they opened. My SIL lives down the block from one of their locations, but we go to the Scotts Addition location in Richmond for the better food selection. I am also mainly an IPA guy, but do love a good Stout, especially a Bourbon Barrel. My last beer there was this....Mark - the Veil makes some FANTASTIC BEERS!....but I'm more of an IPA guy! LOL
...weirdest IPA (that worked) I had (not the Veil) was a Gin Barrel aged Imperial IPA. What a kick *** beer. Sadly, that brewery no longer exists..... are you on Untapped?
Untitled by fouckhest, on FlickrAre those the PAX system cabinet frames? We just bought a couple with drawers and shelves for the redo of our Master closet....
Mike I did my whole kitchen, master bath and laundry room with Ikea cabinets when we built our house. They have held up impressively for 10 years and kept us on budget since my builder apparently only budgeted for about 1/3 or the cabinets we needed. While I cant say I have solid plywood cabonets built from baltic birch, I can say these things work and work well. Looking forward to seeing how this design works out!
Untitled by fouckhest, on Flickr...did you drill into the Ikea cabinets or is that an optical illusion?
Yeah, my cabinets will be screwed to the wall with a top plate. I'm in the process of redoing our master closet (14' x 8') which had the side with all the wife's long dresses pull out from the wall. It was way overloadedThe top board is an illusion, what you are seeing are the pocket screw holes that tie the side board into the ledger board. then the cabinet is screwed into those boards from the inside of the cabinet.
Its certainly overkill, the top of the cabinets will have hanging cloths in them, so any/all weight will be in the bottom. Additionally, they cabinets are screwed to the walls on the side at the points where I attached the 2x4s to the wall.
