Hi gang, newb here.
I put the natural gas version of this in my garage 3 years ago as well. Best thing I ever did. Very happy with it, 3 car garage in IL. Can go from 0 to 65 in 1 hour (degrees that is). I previously had a vent free unit and I swear it made me feel sick. Also the water generated by a vent free was rusting all my tools!
So if anyone is debating vent free vs. vented. Go vented and get that exhaust and moisture out of the garage! I don’t believe the safety of these oxygen depletion vent free gas devices.
I also used an old Honeywell Thermostat salvaged when I went digital inside. Be sure to set the anticipator in these old thermostats. I measured the AC current in the thermostat loop with a DVM when the system was calling for heat. Then move the anticipator setting to that current reading. I just flip the switch from off to heat when I want heat in my garage. I only warm it up when I have work to do out there (or a football game to watch).
I vented vertical due to the many constraints of horizontal (have to use stainless steel vent in my area for horizontal) and all the other spacing/clearance restrictions made it unworkable for me. Just used B vent through the roof and shingle cap outside and spacing collar on inside. Just make sure at least 1” from all combustible surfaces.
After a week of usage I installed vibration hangers since I have a room above the garage. This made a major reduction in the vibration sounds upstairs.
I went black iron all the way into the unit with a shut off valve and service union in last foot of pipe just in case. I hardwired the unit to the nearest circuit (I didn't dedicate a branch circuit either). EMT conduit is code here so I ran that and used some water tight flex conduit the last 2 feet. I would recommend hardwiring and I think it is code in some areas (like a dish washer and waste disposal are).
First time fire up each fall is a bit of an odor as it burns off the dust and such collecting all spring and summer. Usually just last the first cycle.
I can’t say how much I enjoy having this heater. I also can’t say enough how much I recommend using vented heaters.
