My New 30x50 now has power!!!!!!!
royalton10
Lancaster, Ohio
I just installed the Dayton G73 heater over the weekend. I mounted in the corner, similar to your install. I did mine with one bolt so it can swivel. Does yours swivel?
I did a 30 wall switch for the disconnect. Also put up a Dayton thermostat close to the disconnect. The heater works great!!
Doug
bucs012
Doug
No, mine does not swivel but the room is so small at 15x20 with 9' ceiling. I did not feel the need. Mine is plugged into a 30 amp plug in the ceiling above/inback of the unit with the wire up in the attic and then down through behind the wall and into my panel and is on a dual, 30 amp breaker. The knob on the unit is all I have for the thermostat since the room is so small.
