MyMopar
Here are some pics of my new garage. I'm going to need to get some ideas from everyone so if you see something that I could do, please post up.
My plans are to insulate and sheetrock the three outer walls, the one wall the divides the garage from teh workshop space I was thinking of putting a doorway in. I'm just trying to figure out how best to put the sheetrock up. I can add studs to the exsisting wall and build it out, but I would rather lay the studs flat instead of having them "stand out" if you know what I mean. Reason for this is if they "stand out" my lower ledge around the garage will need additional work or trim work.
Outside view:
Garage inside, view of working area and from right bay looking to left bay:
Looking from back wall out of right bay:
Loft over left bay:
Like I said, I'll need to get some ideas. This is what I have planned so far:
* 2 220 volt outlets, 1 to share with compressor and welder and the other if I need to weld on the otehr side of the garage.
* In wall speakers for a clean look
* I have a Modine 60 waitig to be installed
* I am going to run a 3/4 copper loop line around the garage with 1/2 supplies for the air tools. I was also going to run a line inbewteen the 2 doors and make an "old fashion" look alike air pump. Insulated of course and have a shut off.
* Door way between garage and shop
Outside view:
Loft over left bay:
