Newfoundlander
- Joined
- Apr 26, 2011
- Messages
- 12
Hey there, I'm new to the Journal, and thought I might introduce myself with a few pics of my new (last fall) 18 x 32 garage. I've yet to pour the slab, as I wanted to wait a bit for any settling to occur.
My plan is for a radiant heat system, using two circuits. I’m putting 6mill vapour barrier, then 2inch Codeboard from Owens Corning (R-10, 20psi) under the slab and around the edges to create a “floating slab” that has a thermal break from the foundation. I’ll use wire mesh (raised an inch off the stryo) and ½ pex on top of that. I’ve room for about 4 inches of concrete. The contractor filled in the foundation before I had a chance to put insulation on the outside of the frostwall, so, I may have to dig that up again, but I’ll do everything else first and see how I make out electricity-wise. Any thoughts on this would be most appreciated.
Also, I’ve been trying to sort out a thermal break for under the 10 foot garage door. I think I’m going with 1 inch extruded styro, planted a foot deep, with a 45 degree beveled top edge that is at floor level at its highest point. This will be just under the door seal. I think this should keep most of my heat in and still enable me to open the door in the winter… Doesn’t get really cold here, maybe average for our coldest month is -5C (23F).
Anyway, any thoughts or advice you can give will be most appreciated, I’m sure I’ll be back for advice on insulation, wiring, lifts, you name it, as I continue on with finishing my Garagemahal.
Cheers,
Bob
Cheers,
Bob
