Hello. Im a longtime lurker in this forum, and i used the search function alot in my decision. To everyone looking at any tools, use the search feature it really helped in my research, as there are some smart people in here. also Im NOT a professional user, just an average homeowner.
Anyway..
I just bought 2 new milwaukee 12 volt cordless power tools. I bought the Hackzall M12 Cordless Recip Saw, and the M12 Cordless 3/8” Drill Driver.
I choose these because i figured the 3/8 drill would be better than the screwdriver that comes in the combo pack due to its higher torque rating, and since im not a pro user It should be fine for around the home use. I also choose the hackzall because i figured for light cutting around the house and hobbies it should be more than fine. What follows are just my observations.
The drill 1st. It says the batterys charge in 30 mins , and they do. I have not had any modern cordless power tools so this was neat to me. I did some drilling trying to repair some fencing i have, and it performed great, except down to the final end,(3 inch coated deck screws) then it seemed to bog down but these post are old and SOLID, so i'll consider this a win as this is the toughest this drill will ever be used.
the downside. .. I can confirm that the chuck does loosen up in high torque situations. Twice when drilling and im really pressing on it towards the end it loosened on its own, so i had to hold the screwdriver bit and retighten.
The hackzall. The good.I figured for my hobbies that this size for a small saw would be perfect. I initially bought a blade for pruning, and one of those diablo carbide tipped hacksaw blades, i did not use the small blades designed for the hackzall. I always tried to let the tool do the wook at all times. Pruning was awesome with the hackzall and the pruning blade, and also i had one old fence board i played with sawing on, and it cut smoooooth like butter when i switched it out to the carbide tipped wood blade. It has a nice feel and is easy to hold one-handed.
the bad. while it does cut nice, since it has a short stroke it needs whatever it is cutting to be secure. If it is not secure it, it creates a heavy vibration due to its trying to saw, and what it is cutting is moving also. If what you are cutting is secure and tight no problem, if its not then its really a one handed vibrating mother.
Overall i really like my purchases, It was between bosch and milwaukee. I choose the milwaukee due to the warrantee. In the forums ive searched through it seems that these two brands have the best warranties that are actually honored rather than just a paper warranty that once you leave the store doesnt mean ****, plus i really wanted the hackzall. I had a gift certificate from work that i used on this purchase to help on the cost. Hopefully this review helps people who are looking at these tools, as I tried to keep it honest by telling the good and the bad.
Anyway..
