my new old charger
MrSurly
East Texas
Assuming that you are referencing an old automotive battery charger? If so, the older, the BETTER as far as I'm concerned.
Many (Most) of the new chargers are ****, IMHO.
bonneyman
Desert SW
You're not the only one with that opinion! :thumbup:
whateg01
doo dah, kansas, usa
You can't link an email and expect us to see it unless you are going to give us your login info!
My FIL gave me an old charger that had been backed over by a grain truck. I bent up a new case for it and put it back together and it still sees use.
Dave
Farmer J.
UK, Cornwall/Hertfordshire.
Great advantage of an old charger is that they're not 'smart' (like me!) and can be used for powering an electrolysis rust removal thing.. I'm still using a 40 yr old one, it's survived quite a bit of abuse and still has the original case as it's luckily avoided the reversing grain trucks so far.
WinMod21
Found this in a back corner of one of our basement storage rooms, the other day.
Haven't seen or heard of the Kelsy-Stuart brand before. But it's sure heavy, compared to new chargers. Looks rather well used. Haven't tried it yet.
whateg01
Older chargers used a big transformer to drop the output from line voltage to a lower voltage to charge 6, 12, or 24 holy batteries. Many have multiple taps for rapid charging or trickle charging. I've not looked at any newer ones but I'd expect the industry to do like everything else electric and go to smaller, lighter, and less expensive inverter technology. With that comes the ability to define those output voltages through firmware in the charger. Great until it's not.
WinMod21
That's interesting. Thanks for that info.
