My newest table creation
CubbyChowder
I've posted some of my work in here a few times and figured I'd show you guys my most recent project. I guess you could say I've been exercising my mind and hands, I'm always brainstorming new designs and trying to turn my concepts into reality.
I came up with this table top design by sitting down with a pen and notepad, drawing a bunch of squares, and filling those squares with patterns. Eventually I started liking the pattern, and kept evolving it until I was happy with the overall flow of it. I did the same with the legs later by drawing a bunch of rectangles, and designing leg patterns until I like what I've drawn. I went through a ton of different variations before I chose the final design. It's a fun way to create something, and very rewarding when you're all finished.
My neighbor was throwing away a bunch of wood, and I asked if I could snag some of the 2" boards that he was throwing out. They had a cool aged/rustic patina to them and I thought I'd use them for this project, and preserve the aged, weathered look.
After some measuring, cutting and welding, I came up with the basic frame for the table top. Measures roughly 21"x21":
I then cut the wood to the right size and did a test fit. I always like to incorporate flush sitting wooden inlays, it's kind of my thing:
I added some lines, which reminded me of jail cell bars:
Here is a before and after of the "jail cell bars":
After smoothing the welds out, I started tossing around some ideas for the metal finish. I came up with this really busy texture which made it sparkly and shiny, it looked pretty cool but it didn't really feel right, especially with the rustic wood:
Then came the legs, from sketchbook to reality:
I decided to get the table frame powder coated. I wanted to try a "vein" finish that I had been eyeing for a few months, but had never seen in real life, only on a sample chip. I thought it'd be cool, so I went for it, and I'm really glad I did (even though it was a bit pricey at $85 since it's a two step process). I got it back today and am amazed with the results, the finish looks so cool in person. The rustic wood wasn't working for it, so I put my new-to-me jointer to use and cut through the aged wood down to the fresh stuff and finished it off with some boiled linseed oil. I popped the wood in, stood back and smiled at the finished product. Really happy with how it turned out:
What do you guys think? Any feedback is appreciated. Thanks for looking
Mikey
gasaxeman
Hodag Country. Rhinelander,WI
I like the look.
The powder coat really looks nice.I also like the inset wood.
I am into making steel furniture myself.
I will post a couple Picts In the future of some of my tables.
I mostly got into it when I was younger and just married because buying furniture was to expensive.
Do you sell your work?
Keep up the good work.
MonoxieChild
Rockford, IL
I agree with everyone else, that looks awesome! Nice work!
And i love the silver vein. I had my valve cover and intake manifold done in that color on an old car a few years back, and have been thinking of having it done on my current car also. I just love the look and texture of it.
C
CubbyChowder
Thanks for the kind words everyone. Someone asked how the wood stays in place, and it was actually my last step before powder coat so it's not shown in any of the pictures but I just welded a bunch of 1/4" square bar to the bottom of the frame, and the wood just sits on that.
I purposely designed it so that the outer frame of the table top is made with 1" square tube, and everything inside that is 3/4" square tube, that way I could weld 1/4" square bar to the bottom of everything and have it not stick out when looking at it straight on. The wood is 3/4" thick too so it sits flush. Kind of hard to explain, it's much easier to understand when you see it in person.
Tucko
Whittier, Ca
I understand exactly what you did. Well done, Sir. Beautiful work.:bowdown:
Rory Bellows
I love it! I built a table years ago with flat bar and a ring roller that was a gift. It was nice. That table is great. This is my kind of wood working. Thanks for sharing it. You have given me all kind of ideas.
Barlow L
Virginia
that would look great beside my brown leather lazyboy! would fit my coffee cup nicely.
Very nice!
dr_clyde
Holland, MI
Hats off. That's pretty cool. Also curious about your cutoff tool setup? I would guess a chop saw or bandsaw?
C
CubbyChowder
Thanks guys :thumbup:
A lot of miters. What did you use to cut?
For the metal I'm using an M.K. Morse dry cut saw which I recently purchased. It uses a 14" carbide tipped metal blade, and the thing makes amazingly clean cuts. Really happy I bought that saw. I have bandsaw as well which I use sometimes. For the steep angles, I usually have to resort to using an angle grinder with cutoff wheel. I did that for the bottom portion of the table legs.
chris fresh
savannah ga
Diggin the table and the fab work.Nice camera close up work also,is the paint rattle can? or i have seen powder coat with that same hammer finish.
CudaChick1968
Member Emeritus
Northwest Tennessee (38230)
... I thought it'd be cool, so I went for it, and I'm really glad I did (even though it was a bit pricey at $85 since it's a two step process). ...
CubbyChowder, that looks absolutely STELLAR!!! I'd be proud to display that table in my home.
Just so you know though, somebody's seriously pulling your lariat about the "two step process" on your Silver Vein. That -- and any other vein finish -- is accomplished with only one powder and the highs and lows are built right in to the composition. It also looks like you took care of all the proper prep except for the blasting (even down to beautiful grinding and wire wheeling all of your welds ... I'd be inclined to kiss you if you were my customer :bowdown: -- you did all the work and still paid a lot.).
If you want to try something really eye catching on your next project, lay out a candy translucent on top of that Silver Vein ... here's a metallic red you can check out and dream on in the meantime (though your choices are limitless if you choose the right coater).
Keep up the fine work! You have a fan here. :D
C
CubbyChowder
Hey man, thanks for the kind words and tips! I think what the powder coater meant by the two step process is that he applied a clear coat afterwards, but I'm not 100% sure. I would guess that it's similar to the candy translucent that you mentioned, only clear instead. That candy does look nice though, might have to get creative on the next one. Thanks again!
CudaChick1968
Member Emeritus
<< Ummmm, that's actually ME. :D But hey, I've been called worse. LOL! I'm honored to help out when I can darlin. I charge $25 an hour versus a flat rate, and a clear coat doesn't really add anything extra to the bill around here (because I'm working on somebody else's stuff while yours is curing).
Maybe you're one of those who doesn't have signature lines showing, but I own and operate this place. Check it out if you have a few minutes.
http://PhoenixSpecialtyCoatings.com
If you prefer moving pictures, then ya might like my YouTube Intro Movie -- it shows more than just the car parts I customize and restore. It'd be an honor to have a hand in one of your projects down the road. < curtsey >
P.S. Edit AfterThought ... back to work on my Viper parts with a grin now. It's so fun getting to know ya'll :D -- I love this place!! I might clean up okay for an old lady with a used car, but this one is a bit more typical for a work day.
C
CubbyChowder
Thank you everyone!
Haha! I am really sorry! Guilty as charged, I didn't pay enough attention to your screen name or avatar picture. Well I sure feel like a ding dong right now. I really appreciate your willingness to help though, if I was closer I would definitely be going to you. Maybe if I have some smaller parts that are cost effective to ship out!
