MY ODD vintage tool display board
don long
southern california
As some of you may know, I have been given access to a 50 year collection of tools and other vintage items of interest.
As I have been digging through the boxes of old rusty tools I keep finding tools that are very different and I have no idea of there use or value. As I discover these tools I have been putting them aside and cleaning them up as time permits.
I have decided to mount them on a large board and display them in my wood shop.
Here is a shot of the tools to go on display
2019-05-31 11.47.35 by don long, on Flickr
A different angle
2019-05-31 11.48.01 by don long, on Flickr
If you recognize any of these tools , please let us know what you know about them.
I will take close up shots as I mount each tool so let me know what you guys think
Thanks
Don
Provincial
Near Salem, OR
The pliers in the upper center of the second photo, that have a swing-away part on the end and a protrusion on one side is an old reloading tool. The swinging plate is both a funnel for pouring lead into the bullet mold that is incorporated into the tool, and it also cuts off the sprue (tail of lead) left from the molding process.
The protrusion on the side is for resizing the cartridge case and seating the bullet.
Provincial
Near Salem, OR
The pliers in the left center of the second photo are for a piston ring compressor set. This design is useful for engines where the cylinder is mounted to a crankcase by it's base, so the compressor has to be removed from the connecting rod at the split.
Here is an image from the internet: https://cd5a26cb38e2f692acf4-1755b9e4a9778d68267568d15a55e9ec.ssl.cf2.rackcdn.com/54da93df36/93-4.jpg
There are a couple more pairs of the ring compressor pliers at the top of this picture of some of my K-D tools. One pair is offset, the other straight. The rings used with the pliers are at the left of the second picture.
RubiconJK
"I'm bad, I'm Nationwide"
Left center of your bottom photo appears to have two or possibly three examples of Schollhorn/Bernard pliers. There is a thread here on this forum for them.
D
don long
southern california
Here is a tool board that I put together a few years ago when I first came across the collection of tools
D
don long
southern california
Thanks Provincial
I'd have never guessed what that tool was for.
D42jeep
In the center of your picture of K d tools is a pair of door handle clip removers that I used as a body man back in 1965 and also the clip pushes in the top right side.
Thanks Rubicon
I'll look it up
Lugnutz
I just looked at your quiz thread and see that I'm missing only a couple of tools.
Thanks Woody
I'm proud to have them and happy to be able to display them for others to see.
tombell572
Sea Cliff, NY & Portland, OR
Don, the large bit brace in the first pic is a "whimble" style brace. I believe the larger swing is intended to produce more torque than a standard type brace. I don't know the maker but may be more information residing with Mr. Google.
Beautiful and fascinating collection, BTW.
Tom B.
wrenchguy
NW Indiana
The piece that looks like this
is a valve holder & spring compressor tool. The 1 pictured and urs is missing the chain with hook. It holds the valve down with the hook and chain hooked to the wrench looking tool. While applying down force at the end of the (wrench) u'll be compressing up the spring to remove keeper pin.
40cents back in the day, Taken from Model T Ford Forum.
Best illustration of its use is HD Smiths patent drawing.
D
don long
southern california
Thanks for the help Wrenchguy
That valve spring tool was a real puzzler
Rubicon
Those tools are just sitting on the board now but the plan is to drill holes in the board and using a fine tie wire each tool will be wired to the board.
That's how I did the pipe wrench board
RubiconJK
Rubicon
Thank you. Nicely done.
