TheEquineFencer
Onan makes the best. If you're going to use a generator know what you're working with, you get what you pay for. Know how to test it. You need GOOD quality meters;yes METERS you need an amp clamp meter too, Fluke is the best, it's like a Bridgeport Mill, it's what others are judged by. Get one that reads Hz, (frequency). If the generator says it's a 5000 watt, it's only a 5000 watt if it will run at 5000 watts 60 Hz, test it. If you're doing the testing check the no-load Hz. This is the speed the engine is turning. Then load it to full rated load. Do the math, VOLTS X AMPS = WATTS, WATTS/VOLTS = APMS. Don't assume it's 120V do the math. See if it's at 60Hz. Personally, 59 Hz - 63.5 Hz is the recomminded operating range of a generator. Some have electronic governors some have mechanical. Mechanical governors I set at 63.5 Hz no-load and they usually will pull down to 59.5 Hz loaded. If you understand how they work, you can "tweek" a governor to get it right. Use a resistive load for testing, incandestant lights work great, do the math. Then there's what they call inductive loads, MOTORS. Utility power has a lot more "UMPH" than a small generator, kep that in mind. You can cook a small generator end running motors, they will build heat and never trip a breaker sometimes. Honda, Yanmar, ONAN makedecent portables. I've tested them rightout of the box and most will do nameplate rating. The cheap ones from Lowes/Home Depot will almost never come close. If you just running lights, no frig or anything else, it doesn't really matter about Hz, all you're really running is a heater then when you think about it. I have a brand new "off brand" generator sitting here now a guy bought and he's pissed. It's a 1750KW "el cheapo" and the best we can get out of it is 1200 watts. He thought he could run his water pump or frig with it. When you try to start a frig with it, it stops it dead, faster than if you just switched it off! I bought a 10KW load bank to make my testing easier for myself. You can build one to do testing at 120v or 240v if you understand AC power. Please feel free to add comments, I know there's a few more "real generator guys" in here. If there's any of you in my area, come on over and I'll test yours for free. Corona is good, I have the limes in stock!
