texasranger
I've been a long time lurker while gathering ideas for my shop build the last few years while renting. Lots of great ideas here! About 18 months ago my wife and I finally moved into our own place which came with a 24x24 two car unfinished garage. Since then I've been doing house renovations, slowly building my tool collection, and planning my detached build while also working on making the attached garage more useful as a workshop. Several ideas I've found here like the Costco LED lights and an air compressor "outhouse". Figured I would share for those in a similar situation.
So far the following is done:
-Added a 100 amp sub panel
-Added two welder/plasma cutter outlets inside and a 50 amp RV plug outside
-Installed 1/2" copper for compressed air
-Installed an 80 gallon 5HP air compressor outside in a small shed I found on Craigslist
-Converted the two old halogen lights to Costco LED fixtures and added a few more lights over the work bench and blast cabinet
-Added a bunch of 110v 20 amp outlets both inside and out
Over the Christmas break I began insulating/sheet rocking/painting the walls since I am beyond out of space but didn't want to build shelves before finishing. So that is where I am at now..about half done.
TODO list:
-Finish walls
-Electric heater
-Ethernet and Coax cabling for computer/TV
-Ceiling insulation
-More lights
-More shelves
-3 phase converter to run my new (to me) milling machine
-Replace the two old 7x7' un-insulated overhead doors with one 8x18' overhead insulated door
In the long run I will transition most of the tools to the detached garage once I build it, but it may be another year or two until that is finished so this will be my shop until then and afterward it will just be a nicer attached garage.
On to the pics:
Shortly after moving in. I'm guessing the ceiling was installed in '91 when the house was built. As you can see the tape is falling off in several places.
Overhead doors that will be changed to a single 8x18
The overstuffing begins...
The air compressor "outhouse"
My truck "repair shop" since the truck doesn't fit in the garage
Starting on insulation
TODO list:
-Finish walls
-Electric heater
-Ceiling insulation
-More lights
-More shelves
On to the pics:
but I don't have either one yet.
