Prybar
This started out as a $20 Craigslist parts washer. It happens to be a Performance Tool brand but I think its just like the Harbor Freight and all the rest. I don't think it had seen much use but had been sitting around all apart for quite a few years. I wanted to use regular Stoddard solvent but eliminate most or all of the smell in my shop. The pictures do most of the explaining of how I built it with a sealed sump. The pump is a Little Giant brand and the standoff screen at the bottom of the bucket is called a Grit Guard and is used for car wash buckets to keep the dirt at the bottom and off the sponge. The drain plug on my basin was M16x1.5 and obviously that isn't a standard pipe ****** size so I machined down a 3/8npt ****** and welded it in the bung. I used a valve at the drain so I could stop it if I wanted to fill the basin to soak something. The valve on the right is so I can meter the supply from a drip to power spray. Ask if you have any other questions.
View media item 106283View media item 106284View media item 106285View media item 106286View media item 106287View media item 106288View media item 106289View media item 106290View media item 106291
