In this thread - got some great feedback on dimensions... moving on from there - here's where I'm at on designing and specs for the new detached shop...
Here's some updates...
I'm planning to go w/ 24x27 interior dimensions with 10' plate height. It will have a hip roof to match the house (shingle or metal - TBD). I've reduced the window on the left side to just one - keep heat down (though there is a nice view) and increase wall-space. I'll go w/ an 18' door.
I'm going to have the contractor use the same spray as house in foam up in the roof rafters down to the soffits. I'll probably go w/ BIBS (or batting if I do it myself) on the walls. I plan to leave the ceiling unfinished to give access to the rafters for storage - when I look up - I'll see the goopy foam up in the roof but can store boards and what not up there...
If they don't already have plans to do it, I'll be requesting a concrete beam across the middle in both directions forming a '+'. I'm also going to spec a 'thickened area on the left/middle side to about 6" thick to support a potential future lift on that side
I'm going to put in a storage loft area somewhere. I might put it at the back where I might be able to put in a pulldown ladder. Or on the right side over the bench area. I'll hang it about 2.5' from the ceiling joists giving me about 7.5' below it - basically it will be an extra deep shelf for car parts and bike parts... - If on the right side - I'll probably be stuck using a step ladder to access.
I'm going to spec a lot of cabinet height plugs around the 3 walls and a few at standard (low) height. Plus some plugs overhead.
Walls will be drywall all the way up.
Lights - I don't know. Currently I have 4' flourescents screwed directly to my ceiling joists. But I wouldn't mind something new like LED as alon gas they cna readily mount directly to joists.
I plan to coat myself or have coating applied to the floor - like Sherwin Williams Armorseal.
I also haven't decided on some windows along the top of the garage door. It will be a metal door - perhaps a nice wood-grain stained look. But haven't decided on windows say across top row. Door will face towards house and southeasterly - no hot afternoon sun at least. It will have high-lift tracks and a wall-mount opener with wifi and smarthome integration capabilities.
I'll have them bring a data cable over and might also bring an old-school TV antenna coax over (I still like to watch TV off the air). No water (a washbasin will be in the house garage nearby).
I'll definitely put in a mini-split (for cooling in triple digit heat - (heating is NOT an issue)). It will definitely be on the left side somewhere. Maybe middle of wall near or over window or towards back - away from GA door.
I probably should put some insulating foam on the door itself too.
