OzarkMan
So of course its summer time and the "How do I heat my shop" threads are dwindling down as the summer sun bakes. Living in Phoenix, is more of a how do you keep your cool while the four most miserable months begin approaching.
My wife and I are blessed that we found a property 4 years ago in a non HOA area near two major highways for simple access. The house needed a ton of work which I am happy to say is almost complete. It sits on a little over an acre on a very quiet street. Four years ago we hired an architect to help design the addition of a garage, expansion of the back of the house, expansion of the front of the house and the addition of two wings. (A his and hers). Mine is a bright light filled room used as my office with the ability to convert into an elegant dining room when needed on those two yearly occasions. Hers is a 450 square foot dream closet with an island, chandelier and multi zone lighting. It is still under construction. The house has a 5 ton 14 seer roof mounted unit. I didn't want to cut into the ductwork for the new additions to avoid taxing the well balanced ac unit. Instead I opted for three mini splits. One is a 1 ton for my room addition and I don't have pics of it since they were lost on PB. It is also on the other side of the house. The other two I have pics for since I just installed them a few days ago. With the Closet addition, this gave me room to run refrigerant lines over the master bedroom and onwards to the garage. The other mini serves the closet which has two zones.
Here is the completed installation.
IMG_9020 by S, on Flickr
I pressure tested with Nitrogen and let it sit overnight while checking for leaks with soap bubbles. After that I vacuumed down to 40 microns and let it sit overnight. It decayed up to 80 the next morning but we also had air temp fluctuations. I was happy with the outcome and released the refrigerant very slowly using the liquid line first as per manufactures instruction. I then opened the suction line and capped the access ports. Now knowing I had installed more line set than the big unit was pre-charged with, I had to add 8.8 oz of R410A. With the scale zero'ed out, I began the process of adding refrigerant. I also picked up a device that I attached to the tank which converts the liquid charge into a gas. R410A must be charged as a liquid since it is a blend of two refrigerants.
IMG_8981 by https://www.flickr.com/photos/153164955@N06/, on Flickr
IMG_8985 by https://www.flickr.com/photos/153164955@N06/, on Flickr
IMG_8986 by https://www.flickr.com/photos/153164955@N06/, on Flickr
IMG_8987 by https://www.flickr.com/photos/153164955@N06/, on Flickr
My trusty little Bobcat delivering the ac load.
IMG_8855 by https://www.flickr.com/photos/153164955@N06/, on Flickr
Garage before cleaning:
IMG_8370 by https://www.flickr.com/photos/153164955@N06/, on Flickr
Garage ceiling cassette. Waiting on drywall guy to finish up. I hate drywall work. done my fair share.
IMG_8942 by https://www.flickr.com/photos/153164955@N06/, on Flickr
IMG_8612 by https://www.flickr.com/photos/153164955@N06/, on Flickr
Back of house
IMG_8842 by https://www.flickr.com/photos/153164955@N06/, on Flickr
In the end, I find the cooling of these mini splits to be extremely quick, quiet and efficient. Its a great solution if you want to add climate control to your house, addition, shed, or garage. They are so much quieter and efficient over window units of which I had in my last house. They are easy to install with some basic common sense and heeding to the safe handling of refrigerants. Proper tools are must as is gloves, safety glasses and clothing.
IMG_9020 by S, on FlickrI pressure tested with Nitrogen and let it sit overnight while checking for leaks with soap bubbles. After that I vacuumed down to 40 microns and let it sit overnight. It decayed up to 80 the next morning but we also had air temp fluctuations. I was happy with the outcome and released the refrigerant very slowly using the liquid line first as per manufactures instruction. I then opened the suction line and capped the access ports. Now knowing I had installed more line set than the big unit was pre-charged with, I had to add 8.8 oz of R410A. With the scale zero'ed out, I began the process of adding refrigerant. I also picked up a device that I attached to the tank which converts the liquid charge into a gas. R410A must be charged as a liquid since it is a blend of two refrigerants.
IMG_8987 by https://www.flickr.com/photos/153164955@N06/, on FlickrMy trusty little Bobcat delivering the ac load.
IMG_8855 by https://www.flickr.com/photos/153164955@N06/, on FlickrGarage before cleaning:
IMG_8370 by https://www.flickr.com/photos/153164955@N06/, on FlickrGarage ceiling cassette. Waiting on drywall guy to finish up. I hate drywall work. done my fair share.
IMG_8612 by https://www.flickr.com/photos/153164955@N06/, on FlickrBack of house
IMG_8842 by https://www.flickr.com/photos/153164955@N06/, on FlickrIn the end, I find the cooling of these mini splits to be extremely quick, quiet and efficient. Its a great solution if you want to add climate control to your house, addition, shed, or garage. They are so much quieter and efficient over window units of which I had in my last house. They are easy to install with some basic common sense and heeding to the safe handling of refrigerants. Proper tools are must as is gloves, safety glasses and clothing.
