thetastelingers
That rolling toolbox is a great idea!
sweet build.....love the bench n rollintool box idea.....the garage turned out really nice so far....is the inside cladded with the same stuff as the external cladding? ie is it steel or plastic? are you gonna cover up the compressor?
I REALLY like your garage and property. Nice job. But I have to be candid...if I were your neighbors I would be very, very unhappy with that old semi trailer. To the point where I would try to do something about having it removed. I'm just sayin...not trying to create controversy.
is there a reason you didnt put in footings or a middle grade beam? or did i miss it in the pictures
Damn your shop is nice!
Great thread!
Amazing amount of work.
Absolutely fantastic work and attention to detail.
Thank you for posting.
Dan - can you tell us more about your wall hung boiler, what brand, how many btu's? Are you running glycol or don't you ever intend to not have heat out there, with the other plumbing that may be the case....
How is your system performing, its been running for a couple of months now. I don't recall seeing you install any type of heat for upstairs wood area, will you add later, was boiler sized for it? Thanks for any info you can offer.
Very cool shop. In addition to the boiler how much more was the manifold and lines for the radiant heat floor. Our shop now we only need to run the heat when it gets in the single digits. It usually stays around 50 in the winter. But im looking into options for the pole barn im about to build at my new house. 40x80. I plan on doing a loft with custom trusses like you did and use a through the wall unit to heat/cool upstairs. Half will be a 1 bedroom apartment and half will be storage.
