garagesapien
- Joined
- Jul 13, 2022
- Messages
- 143
They'll pretty much leak in any orientation unless the tank is empty.Just a note - keep an eye on your chainsaw. I had mine stored like that for a few months and it dumped all the bar oil on the ground and made a heck of a mess!
Your storage looks like it belongs in a dealer showroom - Looks great!
Thank you kindly!You should design retail displays for Stihl. That looks good. Well balanced and pleasing to the eye.
Thanks for the note, I will have to figure something out for that.Just a note - keep an eye on your chainsaw. I had mine stored like that for a few months and it dumped all the bar oil on the ground and made a heck of a mess!
Lol - They extended warrantee for 4 years if I bought four premix cans, so total of 8 for both chain saw and power head (not at the same time) . I though it was a good insurance. Can can be stored two years from the manufacture date. I am home owner so these probably will last several years.Definitely looks good.
Small fortune in premix sitting there.
thanks for the pictureNicely done, @garagesapien. The family resemblance is clear to the commercial Stihl displays (here at a Rural King in my southeastern Ohio hometown).
those were the attachments recommended for STIHL combi system but should be the same for standalone system?I just noticed that your pole saw is in two pieces. Now I need to take a closer look at mine. It sure would make storing it for the winter a lot more convenient. Thanks for the picture, nice work.
OK, mine isn't part of the combi system. But I'll take a closer look at it to see if it dis-assembles. Thanks.those were the attachments recommended for STIHL combi system but should be the same for standalone system?
I love thé shelf for thé saw and trimmer. Who makes the shelf? Where did you get it?I dedicated small section of my garage wall for all my STIHL products and attachments. STHIL saw, STIHL combi system: attachments and accessories.
Ummm…that is a HUSKY display.Nicely done, @garagesapien. The family resemblance is clear to the commercial Stihl displays (here at a Rural King in my southeastern Ohio hometown).
Hah! It is indeed! I gotta find the right RK/Stihl one then and update my original post. I thought the one in my mind was bigger and more impressive than the one I first clicked on.Ummm…that is a HUSKY display.
Just giving you grief but we get your point
Out here every single thing in that pic would be chained down or behind a counter. Stealing seems to be how to obtain them these days…unfortunately.
I got it from Amazon , search for farm garage Chainsaw Rack. I think it was $98.I love thé shelf for thé saw and trimmer. Who makes the shelf? Where did you get it?
I am using a brackets specifically made for these so hopefully no cracksLooks nice, but...
I made the mistake of storing a Stihl leaf blower vertically to save space, ended up cracking the plastic and some of it caved in to a hole... I guess too much stress on the plastic housing in one spot (recommend storing horizontally). It's not in your display, but I learned that lesson the hard way.
What models and how old? I had a long-time leakage problem with my MS211 - Stihl makes a repair piece (essentially a small vacuum hose connector to push the built-in hose grommet against the leak spot), or you can replace the transfer hose (supposedly upgraded). I finally replaced the hose - I haven't used it much since, but it didn't leak afterwards.How do you keep the bar oil from leaking out?
I've got 2 stihls, both leakers. Was trying to organize the shop a bit last weekend but pause at the saws as I wasn't sure what to do with the puddles....
I forget, but the new one is only about 2yrs old and has leaked since day 1. Summer weight old might be OK, but the winter weight drained out in the warm basement.What models and how old? I had a long-time leakage problem with my MS211 - Stihl makes a repair piece (essentially a small vacuum hose connector to push the built-in hose grommet against the leak spot), or you can replace the transfer hose (supposedly upgraded). I finally replaced the hose - I haven't used it much since, but it didn't leak afterwards.
