My Take On Cordless Tool Storage...
ptgb
Youngstown, OH
Had much "analysis paralysis" over the last couple of weeks for cordless (and some corded) power tool storage.
Didn't want to just throw them in drawer. Many nice examples of hanging under the cabinet, but mostly just drills and drivers... I need to store other stuff as well. Also thought about pegboard (metal), but the hangers you can get are flimsy and not adaptable to specific cordless tools. Also what to do about chargers & batteries.
Here is my solution:
Have two wooden wall cabinets on one wall (old lab cabinets). They most had little used stuff piled in them. Had room for this stuff elsewhere...
Took the middle shelf out, and wiped the interior down with deglosser. The small wood wedges were used in the next step...
Cut up the removed shelf. Cut one side at an angle to meet the back of the cabinet and the other to be 90 degrees to the bottom of the cabinet. Drilled 7 equidistant 2" holes on the drill press. Glued and screwed the this new angled "holder" using the wedges under it as support...
Painted the inside flat black and mounted the 6 way charger and one single charger for my one "big" battery. Also placed the drills, drivers, and hammer drill in place to be able to space other stuff...
Using more scraps from the shelf and some 2x4 supports, I built a shelf to hold all my batteries...
Now, to fabricate the brackets I envisioned, I picked up a bender from Eastwood that bends flat steel to various angles. Slick little machine that makes it easy to bend steel at various degrees...
After measuring and some trial and error, bent up sets of brackets for various tools. Used different widths and thicknesses of flat steel depending on the size and weight of the tool. Primed and then painted...
Mounted specific brackets in specific places for size allowance of each tool...
Room for drills, drivers, chargers, light, oscillating tool, and grinder in this one. Also added a small hook for the cord for the corded drill on the side...
Other cabinet prepared the same way (painted) and rest of the tools mounted in there. Room for some more as I get them...
My whole setup....
Took about 2 afternoons and about $40 in supplies to accomplish it all, not including the bender which I can use for other things.
James-W
Southeastern Wisconsin
I like the way you did those cabinets, they look really nice. Great job!
I like cabinets because they keep dust off of the tools. I have been using shelving simple because shelving is less expensive, it sits on the floor instead of hanging on the wall, and you can see at a glance exactly where the tool you need is located. But still, there are times when I wish I had cabinets.
firworks
IL
That little Eastwood bender is awesome! Adding it to my wishlist.
mrvm
PA
Nice job on repurposing the cabinet for cordless tool storage. That Eastwood bender looks like a nice addition to my arsenal. Much better than the old vise and hammer method. Details on the bender please
P
ptgb
Youngstown, OH
...Oddly enough, the 2 reviews are not so great, but I still want one. :thumbup:
I would give it a great review. It worked perfect with no hiccups whatsoever. Granted, used it just for this little job, but it worked flawlessly.
The only thing that didn't work well was the little rod & flat part that is supposed to be a stop to replicate the same length put into the machine... it stunk. If I wanted to replicate a bend in the same place, I just marked the flat steel.
James-W
I use the hammer and vice method too, but I heat the metal up with the oxy-acetylene torch so it is red hot and then I bend it. This bender would be nice to have though, the heating burns off paint on the metal I am bending and I have to clean it up and paint it again when I am done bending it.
Bessy
Ontario, Canada
Awesome job on the tool cabinets, definitely some stealable designs there that I think a few of us might build upon in future. I definitely want one of those benders now. as I need to bend up some 1/4" rod for the snowplow on my little Suburban Tractor.
LXCam
That's a real nice job on all that! And count me in on another interested in that bender. I like the fact it does a gentle radius as well as what it's spec'd to do for that price.
gearhead1
NC
Nice job! That looks very professional. I also had the same reaction about the bender - didn’t know it existed. I always have need to bend a little something up, but don’t have a big brake.
RDeMeyer
DFW, Texas
I modified my Craftsman floor cabinet for all my cordless tools. Added metal pegboard from [URL="http://www.wallcontrol.com[/URL]
Not sure if I will get the links posted here so people can see. If not I'll find a better way.
ptgarcia
Alta Loma, CA
Looks really nice! Question for the crowd, do you keep your batteries in the garage over winter? I started bringing my expensive ones inside, I think you're supposed to keep them above... maybe 40?
MushCreek
Upstate South Carolina
Nice job! I need to make something nice like that, as I keep my cordless stuff in the basement. The unheated main shop is too cold for cordless batteries. Despite have a nice big barn, I'm going to make a 'winter' work station in the basement for this time of year. It has to be kept neat and clean, as our basement has a guest room and bathroom.
