Ok maybe I should call this a test it was more for peace of mind.
I have had some Harbor Freight Torque wrenches for quite some time, but I wanted better ones. A few months back I picked up a Proto 1/2" for about $60 and it was in great shape
well I went back to that same pawn and they had his little brother the 3/8" for $50 so I got him to. Initially it looked pretty rough but I thought I could clean it up, well it is worse than I originally expected. While cleaning it and shooting PB blaster inside I could see rusting liquid coming out no good
Anyway, last night I was so bothered thinking about I may have just screwed myself over I had to go in the garage and experiment.
I took my Proto 3/8" set it to 75 ft lbs (80 is the max) and I tightened a fastener, I then used a fine marker to mark the location of the nut. After this I broke it free and grabbed the Harbor Freight and started to tighten it back up and sure as **** it clicked on the EXACT spot.
I repeated this test with my two 1/2" torque wrenches set to 120 ft lb and achieved the same result, the line realigned perfectly.
In short while I know this means nothing as far as the actual accuracy of the wrench it was very reassuring to know that it is spot on with the Harbor Freight and I feel that the chances of them both being off the exact same amount is fairly slim.
Anyway, you think anyone copied the other? Proto's on the outside HF in the middle
well I went back to that same pawn and they had his little brother the 3/8" for $50 so I got him to. Initially it looked pretty rough but I thought I could clean it up, well it is worse than I originally expected. While cleaning it and shooting PB blaster inside I could see rusting liquid coming out no good Anyway, last night I was so bothered thinking about I may have just screwed myself over I had to go in the garage and experiment.
