my turn to score a vise
blaze_125
I don't know if I got a good deal or not... but I think I got something decent.
25$
The jaw needs a bit of work, and the whole thing needs a fresh coat of paint, but other than that, it works fine. The handle is a bit bent, so I'll be replacing that tomorrow.
blaze_125
Re: my turn to grab a vise
She's already looking a whole lot better, and she's ready for paint.
lauver
Belton, TX
blaze 125,
I think you did real good. That's an awesome specimen of a vise. Hurry up and lay some paint on it. I would like to see what it looks like all cleaned up.
caper
cape breton
Those Rae's are a nice vise.We have one in the shop that's been abused quite a bit.Check out a set of Record jaws if you can't find Rae's.I think they're the same jaw.
t100
I was few minutes too late on this one: $30 Wilton 4"
http://indianapolis.craigslist.org/tls/1846686992.html
maybe next time.
blaze_125
Since she's now clean and ready to keep going, I set her up in a custom paint booth :spit:
At first I wanted to paint her with fireproof paint. I was at the store with the can in hand and started looking for a primer that was also fireproof. The color was going to be gunmetal. While looking for primer, I stumbled upon a can of BBQ paint for 1/3 the price of the fireproof paint I already had so I went with the BBQ paint.
She looks mean in black.
When I tried to take the vise appart, I wasn't able to get the slider out of the casing. For some reason it blocked near the end and I couldn't see anything that had to be removed to completely slide it out... So I'll paint the slider in 2 parts.
The pictures are of the first coat.
In the second picture, you can see the vise it's going to replace.
caper
cape breton
Sure you can make your own!I usually make them out of aluminum so they are strong enough to bite but don't damage what your clamping.That Rae is a copy of the Record design and like some Records in order to get the sliding jaw out you have to drive the pin out that retains the threaded collar on the inside.The end of the sliding jaw isn't open like most other vises so when you try to slide it out it hits the threaded collar.You have to drive out the pin and wind the handle out while holding the jaws closed.This will force the sliding collar to the end of the screw till it falls off and you can pull it out of the sliding jaw.Once it's out the sliding jaw can slide all the way out of the stationary jaw.
blaze_125
All I'm missing now is the jaw and I'll work on that sometime this week.
Here she is installed and almost ready to rock!
As you can see in the handle comparison picture, I couldn't find a smooth rod, so I went with a threaded rod and respected the overall length of the original piece.
Catamount
New England, USA
Looks nice! I've never seen a Canadian vise before!
Is there any reason you left the two sides together while painting? The only recommendation I'd have is to put paste wax on the slide... otherwise the paint on your slide is going to start flaking off with every use; not that it matters though!
blaze_125
Only because I saw Caper's post after it was already painted.
I wasn't able to take it appart completely.
The paint on the upper portion of the slide will peel off, but the lower portion should stay intact. If the upper portion doesn't peel off fast enough, I'll actually wirewheel it.
I wasn't sure what type of grease I should put on the screw, so I put a **** load of "long lasting" bicycle grease on it. I also baked the paint with a heat gun since my girlfriend wouldn't let me use the kitchen stove.
blaze_125
So it appears at least 1 of the screw hole to hold the jaw is stripped.
Instead of forcing a new screw in there, I figured I should probably re-tap the hole. I've never held a tap in my life ever before.
The screw size is 5/16, do I tap with a 5/16, or do I go 1 size up?
What's the procedure to re-tap a hole?
spongerich
Monroe, NY
Depends on how buggered the threads are. I'd start with a 5/16 and see if you can just clean up what's there. If that doesn't work, you'll need to drill and tap 1 size up.
Underdog
Treasure Coast, Florida
Drill bit the same size as the tap size?
So let say the tap was to be 1/4, the drill bit would also have to be 1/4?
NO NO NO, Drill bit has to be under size so the tap can cut new threads, otherwise the the tap would not have any metal to cut. You need a tap chart that will say what size drill bit to use with the appropriate size tap.
http://www.shender4.com/thread_chart.htm
blaze_125
So she's done and has new jaws.
I'm just anxious to see how well parts are going to hold up in a jaw that doesn't have the texture. Time will tell I guess.
