My Vise Stand
Adrien
Taft, CA
So, I scrounged up some "junk" and built a vise stand out of it. I got pretty lucky find all the right parts and I didn't have to weld anything.
Here's the junk assembled.
I only have this small drill press, so I rigged it all up and drilled my pilot hole in the cap up to 3/8. After that I had to put it in the vise next door and use a hand drill to drill up to 29/64 to tap a 1/2 13 thread.
Here's a shot of tapping the hole. This was my first experience drilling and tapping threads into anything. Needless to say, I was excited and leery at the same time.
Here's a shot of the threads and bolt to be used. It's not perfect...
...but it worked!
Next was drilling the plate to mount the vise too. Once again, my press is only a 3/8 chuck so I drilled up to 3/8 and then had to hand drill the 1/2 hole in the center and the outside holes to fit a 7/16 bolt.
Plate mounted to stand.
For the time being this stand will be holding up a cheapo Craftsman vise I picked up years back and never mounted to anything. It's a swivel base, but the whole thing ***** to one side when you tighten the swivel, and considering the size of my plate the swivel option would be less than ideal anyway. All that considered, I removed the existing bolt and replaced it with a new one to make it stationary.
All put together.
Once my shop is finished and I actually start using it, I'll probably mount this whole setup to the floor and put a better vise on it. The stand itself is a little too tall, but I'm dealing with it for the time being since I was fortunate enough to find some 2" pipe that was threaded on both ends and close enough to working height. For now I'll keep it here at the house for light duty.
Adrien
justanengineer
Motor City
Nice job. You should be well commended for recycling. Pedestal vises are great because you can beat on them without shaking everything off a bench and generally give you more room to maneuver large pieces. If you want it to remain mobile I recommend welding/bolting what you have to a heavy truck wheel, or you can bolt it to the floor if you have room (I never do so everything of mine remains mobile).
A
Adrien
Taft, CA
looks good it it goin to be bolted to the ground
Eventually.
I will be anchoring it to the floor of my shop eventually. I also have access to some more bases that use a large diameter pipe, but this will requiring some welding.
simple but neet :beer:
Thanks!
I was hoping there would be another nice Parker going on it :(
Nice fab work though. :thumbup:
Thanks! I did use a Parker to fab it up, haha. I also have a Parker to put on it, eventually. :thumbup:
Maybe you should have mounted the little drill press on it instead so you can get it off your barbecue grille!
I know, right? My biggest lesson learned is that I need to buy a bigger drill press.
Adrien
whelenfan
Central NJ
looks great. I also think that the mobile aspect is an excellent idea. I will be scrounging for a used heavy duty truck wheel to maybe build something like that too.
