My Welding Table Build Log (4'x4'x.5")
madosta
So, a couple of years ago I picked up these legs from an auction for cheap, with the intent to make a welding table.
So after welding about 10-15 projects on wood tables, and MDF, and a small 3/16" steel plate, and being irritated, I went and got me a nice plate today (for a decent price).
Legs: 2"x.1875
Table: 48"x48"+,.5'
The table legs might have come from a machine shop or something since they are drilled and tapped with socket cap screws.
The plates on the bottom of the legs are 6" square with .625" holes or so. I cant find my napkin drawing from when I was trying to find casters, but I wasn't able to find any casters in a square bolt mounting pattern.
Thoughts?
madosta
I am thinking of building a frame underneath out of 2" square 3/16" wall and then mounting the legs in a sleeve, and maybe a couple "receiver hitch" concepts to put a vice or other hold downs.
Anyone want to drill a ton of holes in it for me and then surface grind it? :)
Nor'Easter
Maine
A fellow I follow on instagram just built a 6x10 3/4" thick, he drilled and tapped 440 holes...
dr_clyde
Holland, MI
Depending on where you are in Michigan I may be able to help you with the holes.
Did I read the top being .5" thick? That my be too thin to grind and maintain flatness, but it can be cleaned up. I know of at least 2 shops that have grinders big enough in my area for your top.
madosta
Those legs look like they were bolted down to the floor, not to casters.
Yea now that you mention it they must've been. I still think I will try to bolt down some casters or maybe we can find some that can fit or be welded.
madosta
Yes sir .5". So it might be overkill to grind it. I am in Detroit and Ann Arbor area.
BLUE72CAMARO
IL
I would look for someone with a big blanchard grinder instead of a surface grinder. It will be a lot faster than a surface grinder and you dont need the super smooth surface finish of a surface grinder for a welding table.
madosta
Ah, detroit may be a bit far for me. If you were closer I'd say you could come use my mag drill.
I do have some friends that live in Holland. I don't know if I want to put all the holes in it or not yet. I love the strong hand tables, but I also dont want to spend hours drilling holes. :) We shall see what happens.
csargents1546
Westminster CO
There is a place in denver call Rathbun. Their specialty is casters. They have a Web page but not very user friendly so give them a call.
madosta
Ok, I'm thinking about having this quoted locally for laser cutting actually:
The holes are 4" and 2" spacing horizontal and vertical. They are .625 in diameter.
I might refine it to match where the supports will go under neath and maybe attach it with sunken socket cap screws...
Think I should leave half of it solid?
What about for an overhang/edge/lip? 1-2"?
tndude
Nice. Let me know how much they quote you. I wouldn't mind building something similar. I like it.
dr_clyde
Holland, MI
Make sure you factor in the taper on the holes. Lasers are very accurate, but holes tend to taper down on thicker metal. If you need a bang on hole size, plan on reaming the hole.
If it's just for drop in tooling, just oversize the holes .005" and call it a day.
