nice table and all.. but talk to me about that elephant sized english wheel!!
A bit of subject (sorry!)
The wheel is home made too
but I imported the upper wheel, quick release & the anvils (Hoosier)
The main frame is made from 10mm (3/8") plate, with the different sizes holes welded in (mostly steam pipe) then 5mm wrapped on the inside & out. The holes where just for looks, but ended up adding a heap of strength. The adjuster I made myself. It tapers from 6" to 3" where the wheels are.
It was left ruff finish before painting to look like it is cast.
I built it a while ago, it is now much traveled, as it was the only wheel at the first few Metal Meets here in Australia, but a 8 hour drive from here. It's even been on TV a few times
Edit: You can still se the weld marks on the mobile bench from when I welded it.
It had to be set up with the 6" edge on the bench & then blocked up to the 3" side, so the centre line was level. Even the mounting faces for the adjuster & anvil holdr ended up perfectly square to each other in both directions, so no twist at all
