I picked up this air compressor pump and it has several problems. Nothing that a rebuild wouldn't fix. Except one it has no memory of who it is and where it came from.
A lot of numbers but no name or brand marking that I can see.
Since I can't get it's pic on the side of milk cartons I thought the combined brilliance of all the member here could help.
What I know:
cast iron block,
aluminum head and valve plate,
two cylinder,
piston dia. 2"5/8,
piston stroke 2"
outlet 3/4
Numbers left side:
block #P100G 21748
cylinder head #70-100-006
#100G 233583
Right side:
block # 70 000 001
cylinder head #050-0008
Front bearing carrier# 045-0010
Piston rod# 047-0008
My hope is someone here might recognize the make.
Thanks to all, regardless whether or not anyone can help.
What I know:
cast iron block,
two cylinder,
piston dia. 2"5/8,
piston stroke 2"
outlet 3/4
Numbers left side:
block #P100G 21748
#100G 233583
Right side:
block # 70 000 001
