Mystery Crimper???
onething
TEXAS
Found this in my Grandfather's tool box while cleaning out my recently deceased Dad's shop.
We have no clue what it was made to do beyond crimping???
main.php
main.php
main.php
Sorry about the fuzzy last photo - autofocus and one-handed photography :sad:
2oolhound
BC Canada
Looks like a saw set for resetting the angle on saw teeth after you sharpen them down a bit.
LesserSon
PA USA
None of the photos show it clearly, but the two anvil supports are arched to form an opening at the bottom. You can see it a little in the second and third images. It fits over the tooth, anvil on the far side, plunger/hammer on the near side. The anvil is usually facetted with different angles to set the teeth at the desired angle, but this one doesn't seem to have that feature. Maybe it adjusts in a different manner.
twertsy
Reedville, VA
I still don't see it. Isn't the hammer pointed in the wrong direction (perpendicular to the tooth) or do we assume it rotates?
LesserSon
PA USA
Okay. Maybe a jamnut or something to keep the adjustment from drifting once it's dialed in?
This shows how it's used:
https://goo.gl/images/SANw89
The plunger has a triangular footprint that pushes the tooth against the anvil. Usually every other tooth is set one way, then the alternate teeth are set the other. Same principle for circular blades.
However, power saws have really taken over in general use, and their circular blades are either so cheap they're more cost effective to replace rather than sharpen, or the tooth material is so hard and long-wearing that it requires specialized expertise.
O
onething
TEXAS
That's why I posted it here! Because you guys know what every old tool in the world is for!!!
