Mystery lot: Looking for Information
Jacobs976
Indiana
Got these pieces in a recent lot and haven't been able to find much info on them yet. Wondering if anybody knows more about them here.
"1/8-C" punch(?)
Mystery tool with roller bearing(1/4 opening)
"1/4 B&D-VD" 4 flute punch
Brass ruler, part of caliper(?)
"J. M. Waterston Detroit" pry bar/bottle opener(?)
FRB in shield "Pat. Oct. '21 No. 3/2 1/4 .3" punch(?)
RoninB4
Under My House
The item in the lower right of the photo ground to a point appears to be from a stamping die. I say this because of the concave shape on the shank. Those would likely be for a "Ball Lock" type of punch and were/are fairly common and unique. When a punch goes beyond service life they often get re-purposed as a center punch or small chisel by toolmakers rather than throw them out.
The small 1/8" C punch could (maybe) also be a used up stamping punch if the head has been ground down to body diameter.
J
Jacobs976
Indiana
Looks like you're right on the bottom right. Also had some "headed" punches I thought were just machined custom order(laser engraved but didn't bring up any results) in the lot which I now know slightly more about thanks to you.
Didn't see any like the 1/8-C in the quick Google search but it'd make sense as well.
J
Jacobs976
Indiana
Also found the pry bar thing (or rather what it was part of). It's a tack puller that was mounted on the back end of a tack hammer. Got stuck thinking it would've been mounted to a cabinet or something like a bottle opener but found a hammer with it then from there a whole page of examples came up.
J
Jacobs976
Indiana
Your brass ruler probably came out of something like this folding wooden ruler, bottom of page
Didn’t see your tack puller in here, but that was my original guess.
Looks like you're right. Might have the housing for it too but if so it's in a bucket of rulers in the shop so I'll have to look.
Didn't see any tack hammers in the catalog at all but I don't have the rest of the hammer so finding an estimate on age or anything isn't a priority.
those were often tagged to be a pair, so look for a number stamped out of sight on the slider (I.e. 34), and the matching number on the body, should make the slide work better. Assuming hand fit back then.
J
Jacobs976
Indiana
Found the body(assuming it's the right one, might be more but I didn't dig around and this housing is missing the piece) so I'll have to clean it up and see if it's a match.
Also slider is marked 49 at the 5 inch mark. Thought it was potentially a date code before.
J
Jacobs976
Indiana
Doesn’t look like 49 was a Stanley model number with a slider.
Housing is a Lufkin. Needs more work before any number can be found to try matching though.
>> this is curious>> FRB in shield "Pat. Oct. '21 No. 3/2 1/4 .3" punch(?) << anything else there?
FRB in shield(letters fused together)
Pat. Oct. '21
No. 3/2 1/4(1/4 in vertical orientation)
.3
That's all in full orientation.
J
Jacobs976
Indiana
Lufkin is a Boxwood No. 372 but no go on a match. Slide is bigger by maybe 1/16. Guess the guy that had them before me had an issue with slides.
