Mystery Tool Set or Tools?
Mr. Tool
Mystery Tool Set or Tools?...well no longer a Mystery!
Maybe someone here can identify this specific tool set and what exactly it is used for? :headscrat
I’ve had this tool set now for sometime but really can’t determine if the set is used for A/C (Air Conditioning services..etc.?) or for Refrigerator services..etc....Aircraft..? :dunno:
Really anyones guess but I’m sure that someone here in GJF would recognize this particular tool set or at least some of the tools.
Anyway there are no markings or names, etc. on the outside of the tool set pouch nor anything indicated on any of the tools or handles either.
Thanks in advance for your post.IMG_3346.jpgIMG_3347.jpgIMG_3348.jpgIMG_3349.jpgIMG_3350.jpgIMG_3351.jpg
Mr. Tool
Pictures just now showing up, I have not run across those drivers before very interesting lot you have there.
Yea, my apologies for them showing up late, thought I had them all loaded up the first time I posted. :confused:
skruft
The roll wrapping looks like a military tool set. I have not seen them before.
Provincial
Near Salem, OR
Valve stem tools? The notched tool on the far left looks like a valve core remover/installer, complete with the hole to clear the stem of the valve. The spiral tool in the center looks like the "easy out" for extracting broken valve cores.
I have no idea about the others.
Kwikasfaki
Australia Vic Wodonga
To me they look like a tyre and tube repair set #3 is a thread chaser for the valve cap #1 left is valve core insert/remove tool, #5 left thread chaser for valve core #6 tools for holding tube in place whilst fitting tyre to rim. Without size it is hard to tell.
4xdog
Santa Fe, NM
Looks awfully complicated and uncharacteristically high quality for automotive valve stems. I kinda like the original HVAC hypothesis.
MShaw
York, Pa.
The fill / check ports on a/c units had a valve that was visually the same as a tire valve but probably different materials.
Mr. Tool
Step it up a notch - think heavy equipment tires. http://www.leemasters-tires-services.com/?p=1643
BINGO!....AND WE HAVE A WINNER! :lol_hitti
No longer a mystery.
Again, a big thanks to all who posted! :thumbup:
EDIT: After a bit more research found this with a bit more detail info:
http://dillaircontrols.com/dill/category/products/tools-and-gauges/service-tools-tools-and-gauges/
http://www.dillaircontrols.com/files/Large_Bore_Tools_52-7B_-_Dill.pdf
http://yourtireshopsupply.com/product/6785/5260-tool-large-bore-di5260
