Mystery tool - what is it?
TreePointer
PA
I picked up some tools at a garage sale and found this mystery item included in the box. 5.25" long, hex shaft with hole, eight metal panels held on by two rubber o-rings. As shown below, I can squeeze the two metal discs into the panels.
It kinda of looks like some type of honing/polishing/cleaning attachment, but the rubber rings don't seem like they belong on a tool that generates a lot of friction. Maybe some type of puller? Anybody know what it is? Thanks.
T
TreePointer
PA
Ah, that makes sense now. Put it in the pipe and spin the shaft to shorten the distance between the discs, which in turn forces out the plates. Thanks, guys!
the gypsy
Montreal, Quebec, Canada
Hi guys and gals this post is a little off topic. Can I use this tool on the inside diameter of a drill press column to spin, like a shaft on a lathe so that I can sand /polish shaft, or do I run the risk of breaking the column.
abk241
SF Bay Area, California
If you want to sand/polish inside cylinders/pipes get a short piece of 1/2" roundstock and cut a slot in one end long enough for 1" or 2" emory tape.
Then simply wrap enough emory around the shaft to get a light or snug fit (depending on your needs) inside the cylinder and chuck it in your drill.
I've got a few of these laying around and have used them for years to clean up nicks in bearing bores and to open up bushing bores where needed.
BTW...you should have started a new thread for this...IMHO
the gypsy
No I do not want to clean the inside of a cylinder. I want to use it to drive a cylinder. The opposite of a chuck on the outside clamping the cylinder. I wanted to know if there is a danger that I break the cylinder.
90zcar
I'll expand on this.....if it's the harbor freight expander I'll tell u exactly what it is.......JUNK!!!!
Sent from my iPhone 5s using Tapatalk
alwaysFlOoReD
Airdrie, Alberta, Canada
It probably isn't going to be balanced well but I would give it a go.
Richard
A_Pmech
IL
Those really aren't expanders, although they're sold as such. At most, they're dent removers.
Mechanical Noise
Southeast of O'Hare
Exactly. And I usually had to tap the clamp groove flat with a hammer against the "expander" before I could reuse the pipe or muffler.
Pretty much a lost art since the elimination of leaded gas and exhaust system maintenance.
abk241
Guess I should have had that 2nd cup o'joe before logging in.
gungatim
west mich
really? I have 2 different sizes and have used both of them dozens of times. the pipe expanded every time. may not be as smooth and round as a machine, but gets the job done and seals just fine with a muffler clamp. have never had a problem using them.
