Mystery Tools That Need A Name
JASTECH
Gering, NE
I thought this should be puzzling and a challenge to stump GJ members.
Please join in with your tools w/o a name.
Thanks, JASTECH & Son
WWIIjeep
Arizona
Outlaw beat me to it. They're Phillips Red Head self-drilling snap-off concrete anchors. Also called "tooth anchors."
The tapered end fits in a special chuck in a hammer drill. There was also a straight-body style for hand-hammering instead of power hammering.
They're obsolete, and even when they were available, they were a PITA to install in anything resembling hard concrete.
zuk123
Houston TX via Chicago, Phoenix, LA, and San Diego
OK, I'll play too. Some of you might have seen these in the yard sale thread. I still don't know what they are. NO marks of any kind.
zuk123
They are pretty small to be hoof trimmers, and not sharp at all. The wide end has the same shape as a vise (only tiny.) The dovetail in the handle intrigues me. And the shape of the space at the end of the handles is slightly rounded, like the profile of a round head bolt.
Probably all irrelevant, but...
I've never seen anything like them. They are well made.
zuk
J
JASTECH
Gering, NE
Here are few more that need I.D.
signcrafter
That last picture looks like a hand jointer for squaring up a 90* corner on a piece of wood.
Provincial
Near Salem, OR
The second photo is a guide from a sickle bar mower that is attached to the 2-pulley block with baling wire. How do you say "farmerized"? The guides are attached to the bar of the mower like teeth and the sharktooth-shaped blades rivet onto a reciprocating bar that moves them back-and-forth through the groove behind the point of the guides.
J
JASTECH
Gering, NE
Outlaw, here you are. Zoom, sence you work at Ideal maybe you can help?
Stick
Alaska
They look like the type of tool used for crimping the ears on CV boot bands.
Phixer
Sacramento, CA
this thing stumps me... shown with lever at extremes of swing. no markings anywhere.
(blue tape is irrelevant)
zuk123
Here's another one, I got it in a bunch of tools at a pawnshop.
It's marked RIMAC and has a 3/8 hex on one end, and a smaller one on the other, so wrench of some kind, but for what? And google has nothing on Rimac...
zuk
Captain-Matt
Jastech, your Ideal thingy looks like the sort of thing for chasing grooves in sheet metal for decorative repousse work. I can't remember the name of it though, sorry.
zuk
Old style brake bleeding tool.
knotheads
zuk
brake bleeding wrench.
Steroblan
Northern Calif
Maybe a tool for setting link pins from early chain driven vehicles. The portable tool could be driven into a nearby tree or nailed to a fence post for use. Just a guess though.
How about this one?
Hard to tell with only that pic, but it appears the collets go into the "top" (picture reference) and I'm guessing are for gripping several sizes of precision ground stock. does the collet holder inside run on bearings/bushings and "free wheel"? can you run through the center for the ID of the collet (meaning are the collets restrained with an open/hollow "drawbolt") Is there a place for some sort of cutter on the arm opposite of the crank handle?
I'm thinking a setup for cutting a groove, possibly for Snap rings or O-rings, in something that required either on-site installation, or precise custom fit at the ends of random lengths of whatever was being cut/installed.
Also, any markings on the box or tool?
Phixer
Sacramento, CA
Hey Phixer, is the piston/press rod part moving? Does it open enough to put something in it and compress it?
There are tools that look like this only slightly smaller for the AV industry to put ends on cables.
Do you have a bigger pic?
zuk
Okay, here is a larger view... approx 1" of travel, the "probe" end has the most wear in the 3/8" notch area. There are slight wear marks where the barrel slides along the rod (above blue tape). So possibly it engages the work piece in two places? I'm stumped!
