Nail Gun Hole-Fill?
jaymar_
Using a finishing nailer to put up nice ~1/2" ply on interior garage walls. I assume this means I can't paint the sheets until they're up. What's the best material to fill the holes with before (non-oil-based) painting with roller, so the holes (and filler) don't show? Best grit to sand with? Finally, what is the order of easy-to-clean finishes? I'm thinking gloss, semi-gloss, satin, matte, flat? TIA!
J
jaymar_
Should have said I'm not using oil-based paint. Edited above.
428PI
Peabody, KS
I put up car siding with flat out and face nailed because I wanted a granery look. No finish to worry about either.
Shiftless
East Bay SFO
How finished of a look are you trying to achieve?
Caulk, bondo (spot putty), hot mud..
I’ve been using that 3M 907 product for a couple of years now. One possible problem for you is that the stuff is red. The color is so different than what it is usually applied to that it takes an extra coat of spot priming before you apply the final finish. If not, it a shadow of darker color might show through.
jar944
Northern VA
Works great, but I wouldn't want to do every nail hole in a garage with it.
Shiftless
East Bay SFO
Yeah, I like it for critical applications like your interior panel. It sands so easily. You can use it to rebuild nicked corners. But for garage nail holes on textured surfaces, I’d use caulk and then smooth it out after a few minutes with a damp sponge.
jar944
Northern VA
Works great when a drying rack of freshly painted cabinet doors and drawer fronts falls over.. DAMHIK..
For a garage I'd just fill the holes with setting compound/hot mud since it doesn't shrink. Everything else us a 2-3 application process to get a flat finish, Even the bondo putty.
bb29510
trick painter taught me, before nailing, nail throught a piece of painter tape, then wipe the filler and pull the tape off, no sanding needed
