Nail plates ... where to put them?
Dick in Wisconsin
Shawano, Wisconsin
Wiring the new garage/race shop. I've drilled holes in the 2x6 studs to pass the Romex through for the wiring.
I know I have to have nail plates where ever a hole is to protect the wires from nails. Is the nail plate required regardless of how deep the hole is into the stud? I can see if the hole is close to the edge of the stud a nail plate would obviously be required. But what if the hold is in the middle of the 2x6?
D
Dick in Wisconsin
Shawano, Wisconsin
I should have asked before I drilled the holes, pulled the wire, and hooked up the receptacles and switches!
I have 1.5" x 2.5" plates. Are presume they are long enough.
Thanks for the quick answers.
Ray-CA
San Diego CA
If less than 1.25 inches from face if stud to hole, than it is required to be plated.
This is what the 2010 code requires. I put a plate over every wire just in case. They are a lot cheaper and easier to install then it is to open up a wall and repair damaged wire.
Ray
