Nailing 2x4 to new slab
Cadmandu
Va
I have a week old 4 in slab how many days old should my slab be before using a ramset 22 cal nailer on the floor
jack stand
Lakes Region Maine
I use "fluted" masonry nails and construction adhesive to fasten plates.
Don't overdo it if you're hand nailing but you stated that you were using a Ramset. A single nail every 2' with the glue will do it. At 4 weeks your fine, sometimes we'd do it in days. Use the good poly something glue with the wet pt lumber.
jrsavoie
North east Illinois
I have taken to using PVC dimensional on concrete.
I have had occassional difficulties with the nail gun and just use female or male drill in anchors anymore.
Does anybody forsee issues with usingnthe PVC dimensional boards for a bottom plate?
Over the decades, I've had issues with both treated and untreated wood used on the bottom plate. I hate having issues, no matter how many years have passed.
There are also potential issues with improper fasteners in treated lumber. The fasteners can disappear faster than what you might think.
K'ledgeBldr
Johns Creek, GA
How do you use adhesive if you are using foam sill sealer?
Clearly not using sill sealer!
Nice thing about sill sealer- it isolates the plate from the slab, which inhibits moisture transfer. But, that’s also usually just exterior walls- not interior walls. So, I guess there are two trains of thought.
C
Cadmandu
Va
No just framing out a wall inside my pole garage
jack stand
Lakes Region Maine
Can I use liquid nails on wet treated 2x4 to new concrete
Check the label. Iirc "locktight premium " was what I was recommending above. I think the "poly something" that I couldn't remember might
Ok, you made me look it up😆
Locktight PL premium 8x
The word I forgot is polyurethane. I think that's the key no matter the brand or manufacturer. 👍
jack stand
Lakes Region Maine
By the time the electrition bangs on a few receptacles and switches and the drywall guys finish there beating on the walls, on top of a not so tight fit due to not framing it in place... I've seen masonry nails loosen up. 👍
C
Cadmandu
Va
I read that some guys drill a 1/16" hole and drive (2) 6 penny nails in. I'm framing out around my panle for now so il going to glue and screw this one 2x4x8
