5lima30
Tie betwwen a shovel and a pick axe. Where I live they go hand in hand!
Not fun to dig up there.Hex Wrenches. Lets design a fastener tightening tool with 35 standard sizes and 35 metric sizes, which don't have any practical way to keep them together, where the 'fast' drive method is still slow and the 'slow' drive method takes a ridiculously large/clear area to swing the wrench, where the torque required to remove a fastener is more than the base material can handle without snapping. On the other hand, the hex wrench brings us the single coolest-looking fastener in the entire world--the socket head cap screw.
Another is the post-hole digger. Seriously?! A powered auger is worth the money spent to rent. When I put in my fence last year we did 36 24" deep holes in 2.5 hours with a 2-man auger. It would have taken easily 4x that long with a post hole digger.
True... but if you're just digging one mailbox post hole, I suspect a post hole digger (and a shovel to go with it) isn't such a bad option. That said, I've helped dig fence post holes with one so I know what a backbreaker it is.
one of the first times I met my FIL my wife (then girlfriend) enlisted my help to put in a fence around their back yard. my FIL had a posthole digger and two shovels, and when my wife and I showed up at 10am, he had been going at it for three hours and dug one hole. I promptly called the local rental place and got a 2 man auger and had the remaining 40 holes dug by dinner, and returned the thing back to the rental place.
after seeing one used to dig deck footers, I vowed to never use a damn posthole digger.
such an inefficient tool.
Good point. Nice to see a local btwI'm just right up the road from you.
It must depend on your soil. A couple years ago, my dad, after he was done his work for the day, would drive out and put in 2 or 3 posts. Before harvest he had finish a mile of barb-wire fence. Mind you, he is the only 67 year old I know with washboard abs.
Slotted or standard screwdrivers!
The impact driver that you smack with a hammer to break screws loose (Like on Honda rotors). The 1/4" shanks always break. They need to be 3/8". Anytime I run into those rotors, I just grab the air hammer and chisel bit and just skip the headache.
