Name that Horizontal Mill
RKSpeed
Augusta, ME
Found for sale locally. Can't find serial numbers or name plate anywhere. Any idea who made it?
dwcon1431
No idea but, it appears to be older than I am and that's really old!
Sent from my SM-A102U using Tapatalk
DocsMachine
It's older'n you an' me both. Rough guess of late 1800s, back when most of the horizontal mills were made from lathe headstocks.
The motor and whatnot are almost certainly later add-ons, to be able to use it by itself, rather than attached to an overhead line-shaft system. (Note the jackshaft uses vee belts.)
Couldn't say on the make and model, but one identifier might be that collet. It's hard to tell the scale, but if that's a 5C collet, that'd narrow it down quite a bit. I think the 5C came out in around 1890-ish, and for the longest while, was pretty much limited to pre-Hardinge Cataract lathes. (That's where the "C" comes from, by the way.)
Of course, the spindle could have been re-fitted years later, so even that's no proof...
I'm not helping much, am I? :D
Doc.
GrantCee
Willamette Valley, Oregon
Hmm...that's an odd one. The table design is unique.
I think I see a name cast into the metal above the plywood where the motor mounted. Got a better picture of that area?
You should post these in the Antique Machinery forum on practicalmachinist.com. That's where you find the lathe and mill fanatics.
matt_i
No offense but I don't think its a good deal if you want to do actual metalworking.
Would be very cool as a restored piece of art.
