name this tool
scootro
Arkansas
Anyone know what this is?
Kevin54
MEMBER EMERITUS
Urbana, Ohio
That's what I thought at first was possibly a crimper or corrugator for sheetmetal, but if it was, I don't see why it would have a lock on it. Take a little oil, or a little WD-40 and wipe where the writing is and see if you can make out the name of the company on the side.
scootro
Arkansas
it's not mine! i found these pics on my favorite forum. i figured you guys would know what it was
http://www.dfwmustangs.net/forums/showthread.php?t=47865
Kevin54
MEMBER EMERITUS
Urbana, Ohio
If you look close at the gear on the side, the teeth are designed to only go one way and not back uo. If it was a crimper, the teeth would be straight up and down, plus the upper roller would have a tooth pattern to it also that would mesh with the lower gear or wheel.
At least that how I figured a crimper would work. What is the spring tension adjusting? It looks like that arrow looking part to the right of the crimper style gear.
