$2150+tax is what I paid. Not sure if they'll honor it for everyone, but for $150 more than the discount price for that other lift, I'm very happy.
Does any of the board members have the Triumph C7000 installed in the Dallas Fort Worth Area? I would like to see the lift in person is someone nearby has one. Thanks in advance
Jay
If someone PM's you, please let me know as well. I'm in DFW and would like to see one in person.
NAT is located in Fort Worth. Maybe you can just go there and check one out?
i emailed and received a reply that they are not offering any discount on the lifts at this time.
Supply and demand....must be selling well.
Also, regarding wheels. I can't say what it would be like to roll these posts around if it had the build it wheels but I think for the few times I do it that I will be happy using my hand truck.
I received mine a few weeks ago. Trying to get the garage cleaned up so I can stand it up and figure out where I want it mounted. What spacing are you guys using?
I am jealous of that price JonM got!
I have mine spaced with a 101" drive through clearance.
jacobsed,
I see that you used Wejit expoxy anchors for use with 3/4" bolts. The lift came with 5/8" bolt anchors (actually 16mm) and the maxjax also used a 5/8". Any particular reason you went with 3/4". I was planning on using the 5/8" bolt epoxy anchors from wejit.
What size pads did you pour?
jacobsed,
jacobsed,
What epoxy did you use and how much did you need. I am sorting through mcmasters site and weijets site but mcmasters uses different part numbers.
where do you place the jack pads on your vehicle for unibody cars. Do you use the spare-tire-jack points directly behind the wheels? This is what I usually use for jack and jack stands.
Depends on the weight distribution. Bendpaks come with a chart for just about ever standard car. Not sure what this comes with.
on bendpaks site page 30 to 33 on PDF also most factory manuals will have the lift points in them
http://www.bendpak.com/XPR-9D Manual 5900046 REV C 02-03-14.pdf
The price difference is ~$3 per anchor. For less than $20 per post I'd rather have way overkill. Don't forget the C7000 lifts higher and has a larger weight rating than MaxJax.
I'm not comparing this to Maxjax. The C7000 ships with some M16 bolt (~5/8) - 7/8" hole, no name drop style anchors. There are no specs on these but the max tensile strength of any similar product on the marker is 16.5k. (Using Wejit PD58 as example). I doubt the no-name anchors are anywhere near 16k.
The Powers 3/4" bolt - 1" hole, drop in anchors that some early installations shipped with only have a tensile strength of 10k lbs in 4k PSI concrete
(Source: http://www.powers.com/pdfs/mechanical/06308.pdf)
The Wejit 5/8 Bolt - 7/8" hole, Power Sert epoxy anchors have a tensile strength of 26k lbs! The 3/4" Bolt - 1" hole epoxy anchors you used have a tensile strength of 46k lbs!
(Source: http://www.toggler.com/wejit/techspecs_power_sert.html)
I spent a lot of time on this, and the 5/8" Epoxy anchors far exceed anything shipped with the product. The 5/8" anchors also exceed the tensile strength of the 3/4" stud installations used on much heavier duty lifts. The concrete will break up around the anchor before these anchors pull out.
As far as I know, they still ship the Powers anchors with the lift (along with the no-name that come from the lift manufacturer). In fact, NAT contacted me a few weeks ago about sending them some pictures of my lift in exchange for some free product. I chose a second set of anchors and they sent me another set of the Powers.
