alxdgr8
Odd, I'm sure they'd send you some if you asked, but it sounds like you have a better solution.
Here are some pictures of me determining the location in my garage.
Due the length of the lift arms, to get proper placement with my Subaru Outback, I needed to space the posts at 106" apart (front edge spacing).
My cement is only 3" so I cut and demo'ed a 4ft x 15ft section. I am going to pour a 12" thick slab.
8 ft. I will only be able to lift 4 feet or so. I do plan to set up some anchors in the driveway at some point so I can do full height lifting if a project calla for it.
Wow, these look way beefier than the maxjacks, what are those string pulls on top of the lift head?
I just had the lift delivered today. Haven't had a chance to take it apart yet but I noticed my arms are only double telescoping. Just e mailed NAT to see if there was a design change and if it is going to change any of the measurements. Looks like a nicely built lift and it was well packed. A bit of a *****
to get off truck. Can't wait to install it!
How doe the auto lock work?
Hi all,
I'd like to echo this question.
Does this lift have multiple stops (say every 3 inches) like full size lifts? If not how many positions does it have?
Also, how does releasing them work? In the pictures above, I see a pull on each post. Do you have to make sure to pull them both to release the locks? Seems like it would be difficult to pull both releases and lower the lift by yourself.
Thanks guys!
Mike
Mike, I sent you a PM with a link to a review I wrote about this lift.
When the lift is fully lowered, the lock reset and its ready to automatically lock again once you raise.
No need to make this private I guess, wrote the review on Amazon for anyone to see.
http://www.amazon.com/gp/product/B00QHEV3MM/?tag=atomicindus08-20
Well guys, I just placed my order for a C7000 from NAT!!!
I can't wait for it to get here!!!
My one worry is delivery. Residential address, no forklift, and I don't have a pickup truck.
They said the delivery truck would hang around for 30 minutes. I plan to have myself and 3 or 4 other guys unpack it on the truck and unload each item individually. I told NAT about this and they said that will work.
Wondering if anyone else has any opinion or words of guidance on this.
Thanks in advance for any help!
Mike
Mike
Eat your Wheaties that morning.
are you getting lift gate service ?
engine crane and dollies will work after it off of truck
