Natural gas to propane
69boss9
N/C Illinois
How hard is it to convert a gas dryer and stove to propane? I understand you have to change the orifice , but I am not sure as were they are located is in the gas valve ???
aandpdan
In between MA and PA
The orifices, at least in most stoves, are at the burners - including the oven and broiler. You then convert the regulator and set the "low" position on the gas valves.
You can get a conversion kit for your model at most parts stores. They aren't usually that expensive and have everything you need and best of all, directions.
maxspeed96ct
sears might have the parts your looking for, check thier website .. Normally you just have to change the orifices and adjust the regulator .
ForceFed70
BC, Canada
Going from propane to nat gas can be done with some know-how and some very small drill bits.
But, going the other way requires smaller orifices. You'll need a conversion kit from the manufacturer.
rkevins
Central Arkansas
You need to check with the books for your appliances, some conversions are just adjustments and sometimes you will need a kit.
Socophreak
You will need a kit to change the orifices for going from Nat to LP.
You will usually find the orifices at the end of the burner by the primary air intake. Make, model and serial number will definitely help tracking down on directions.
D.J.
New Haven IL
Some stoves have the replaceable orifices tied onto the back of the appliance on a little thin wire.
larry4406
Northern Virginia
My new natural gas furnace came with a conversion kit to change to propane. There were new orifices as stated. I also had to borrow a manometer and adjust the regulator while the furnance was running.
