I am rebuilding a vacation cottage so will need to install a new meter and 200 amp/240 volt service disconnect to comply with NEC 230.85.
• Can I use a Service Disconnect or does it have to be a circuit breaker? I have worked in industry for 50 years and found that circuit breakers fail more frequently in humid locations exposed to hot and cold ambient temperatures so I want to use a disconnect outside.
• Can I get a Service Disconnect that I can install a fireman's lock in the ON position to ensure no vandals can turn the power off in the middle of winter. We won’t be around for much of the winter.
• Does the service disconnect have to be mounted on the outside of the house? I would like to install it with the meter on a backboard next to the garage as we will have underground conduit to the house.
• I want to install a generator to cover the frequent power outages powering only the furnace and heating recirc pumps through a subpanel. Can I install the transfer switch inside the house at my breaker panel?
